bladerunner1968
Cheers - I think I can squeeze the DC-DC charger into where the lifepo4 is going. If I go for 6 metres of 25mm cable at 14v over the 6 metres for 60A I get a drop of 0.5v which is OK for the Renogy charger based on their specs apparently.
I've also found a chassis earth point right underneath the fitting location which the original converter was using - I can replace the current -ve cable with a bigger 25mm over a 2 metre run which is great.
