Van-X Dash Upgrade.
I see they are back in stock now at van x.Anyone else bought the glove box and air vents?.Curious as to what people thought before i dive in..
Search van x dash and theres a how to do it vid on there.
Just got meself one it doesnt look to bad,not fitted it yet tho...
Ok so I bought the Van-x T6 comfort dash glove box and have had it sat in the box while I source a light for it, with no success.
Decided to install it and it’s like having a bass drum in the van when there’s not a lot in but problem solved bit of silent coat and an off cut of carpet to line it should do the trick.
Now have to wait for can of spray glue to arrive as run out
Will add finished pics when done.
2A79D2D2-20C6-4ACA-BF39-45B751E00B1A.jpeg D0A4F5F8-6922-446F-B38E-A07238C231CF.jpeg CA108389-F1D6-4E44-90BE-82704F38F6AD.jpeg 63C7561A-6F53-4192-B677-F04C2157223D.jpeg 757FBB3A-9F6F-4D80-8C00-3F2B18C17158.jpeg
What light are you putting in it and where from?. I need to do the same to my glove box.
I am not at the moment as the hole is set for the usb plate to allow retention if you do,the full dash upgrade and 8 couldn’t find anything to fit the same size. What I will probably end up doing is installing one of the foot well LEDs with a small toggle.
that lid one looks good, think this colour will suite better than the gloss one...
I bought a gloss one and sent it back in exchange for the matte. The quality of the one i had is good in my opinion. They have a cut out if you wanna put a light in. Good idea to line it though.
Just got mine... stripped it to be painted. Did the silent coat work to resolve the drumming? Is it worth doing before I put if in.
The silent coat definitely sorted the drumming out and it’s definitely worth doing before you install I also carpet lime mined.
I have fitted mine and moved the USB port into it. Unfortunately the port with the green plug is too deep and hits the centre air vent so it won’t fit flush in the glovebox
