VB Air and KONI are both Dutch or were. I guess it was down to costs for VB Air. They do not seem to change much from what they started from. I think from memory, it was approximately £7 and a half thousand plus something, its on there website to fit VB so they could be more accommodating with design or what ever. Perhaps the Transporter revenue was very small compared to the rest of VB Air catalogue including trucks and what not. KONI as you know also have a huge base to supply , trains F1 and anything and every car imaginable. No doubt several versions for each. I like the top adjustable dampers, it is a pity that they did not extend that to the rear dampers. It becomes more of a pain taking them off or partially removing, then compressing to move to the next position. Particularly as one gets older and when working in the filth on a small holding. I have noticed the KONI racing dampers, that some are adjustable separately for compression and rebound and it looks like they can be adjusted on the vehicle which would be very nice and convenient. I also imagine Expensive ££ perhaps and that they would need setting up in advance for a staring point on any particular vehicle and then settle for a range that the valving might operate in between. Quite surprised that some of these have not been directed towards the enthusiast.It is a great pity , VB air are clients of KONI , BUT they dont buy the KONI dampers for the transporter kits ??? , It probably wouldnt help the issue that so many people are having with the fronts deflating with out warning but the kit would ride miles better . The VB Air front strut has a very unusual upper mount so replacing the dampers with something better is probably not doable .
I am not very Keen on Bilstein. Though among there range include dampers that are adjustable some have separate compression and rebound adjustment. Unfortunately they all seem from what I detect, directed at Bum Scrapers and not those looking for any sort of lift. I think that they also cater for air but probably standard production I guess.
Air as an after-market, is probably a very small market. It is hard enough to convince many even that they that they would be better off changing original fit dampers for better quality units. It is also the same with tyres. Their are those who always want the best for there particular circumstances, those who just want posing rights and those that do no even bother checking there tyre pressures. The latter possibly just fit any old generic tyre that fits and costs the least.
