Thanks for the rapid response mmi - but it was!Ignition needs to be ON.
Hmm... interesting. Could you please post an Auto-Scan - just use default options (Auto-detect etc.) and Start.Thanks for the rapid response mmi - but it was!
I'm wondering that as I removed the instrument cluster (and later replaced it) and the gateway module (and then replaced it) - do I need to do a 'reset' of any kind?
Saturday,19,November,2022,19:44:07:38189
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZMH054892 License Plate:
Mileage: 7544km-4687mi Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F 75
VIN: WV1ZZZ7HZMH054892 Mileage: 7544km-4687miles
08-Auto HVAC -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
Address 01: Engine (J623-CXHC) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 SC HW: 04L 907 445 M
Component: R4 2.0l TDI H01 9970
Revision: 23301001
Coding: 001140144344050900000000000000000000000000000000
Shop #: WSC 00012 790 00065
ASAM Dataset: EV_ECM20TDI03004L906056SC 005007
ROD: EV_ECM20TDI03004L906056LE_005.rod
VCID: 00598D9C0A8A51DBEB2-8055
VINID: 9E606AAAA1D8A9D60014420908F4904341
2 Faults Found:
25810 - No Communication with Instrument Cluster
U0155 00 [032] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 7517 km
Date: 2063.15.31
Time: 16:00:00
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 10 °C
Intake air temperature: 4 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 10.812 V
Accelerator pedal travel: raw value: 0.00 %
CAN status - engine control module: 0
Cruise Control System (CCS): status: Initialization
selected gear: Shifting process active
25126 - Implausible Data Received from ESP Control Module
U0416 00 [032] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 7517 km
Date: 2063.15.31
Time: 16:00:00
Coolant temperature: 9 °C
Intake air temperature: 0 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.859 V
Acceleration: 0.000 m/s²
Average vehicle speed: 0.00 km/h
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Drivetrain coordinator: brake function status-ABS intervention: No
Drivetrain coordinator: brake function status-ESP intervention: No
Drivetrain coordinator: brake function status-EDL intervention: No
Drivetrain coordinator: brake function status-ASR intervention: No
Drivetrain coordinator: brake function status-MSR intervention: No
Drivetrain coordinator: brake function status-Driver braking: No
Drivetrain coordinator: brake function status-HDC active: No
Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
Drivetrain coordinator: brake function status-EPB active: No
Drivetrain coordinator: brake function status-ASP intervention: No
Drivetrain coordinator: brake function status-ADS intervention: No
Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
Drivetrain coordinator: brake function status-ACC stopping distance control active: No
Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
Drivetrain coordinator: brake fault status-ESP system error: No
Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 7LB 614 517 B HW: 7LB 614 517
Component: ESC_base H01 0800
Serial number: 08505890201207
Coding: 30552452484CEE890C5C24AD12687726392324B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
VCID: 3FDB4E6037F4EE23D28-806B
No fault code found.
Address 08: Auto HVAC (J301) Labels:* Redir Fail!
Part No SW: 7LA 907 426 F HW: 7LA 907 426 F
Component: AC Manuell H01 0602
Coding: A03110000810030001000800504001050000000000000000800000000000
ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
ROD: EV_AirCondiBHTCVN54XT6PA.rod
VCID: 46D55B84682EBFEB91E-8013
Rear air conditioning block 1:
3 Faults Found:
459523 - Databus
U1123 00 [008] - Received Error Message
[Botschaft Dimmung_01 - empfangener Fehlerwert]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Date: 2000.00.00
Time: 00:00:00
1048838 - Functional Limitation due to Energy Management
B10CD 00 [009] - -
[Funktionseinschränkung durch Energiemanagement Ruhestrom]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 9
Reset counter: 126
Mileage: 6166 km
Date: 2022.08.21
Time: 19:33:20
Voltage terminal 30: 11.2 V
CAN input signal(s) status-Transport mode: On
CAN input signal(s) status-Static current measuring mode: OFF
CAN input signal(s) status-Windshield wiper: OFF
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
CAN input signal(s) status-Wipe wash: OFF
CAN input signal(s) status-Rear window heater actual value: OFF
CAN input signal(s) status-Back-up lamp: OFF
CAN input signal(s) status-Actual value of windshield heater: OFF
Blower reduction: No switch-off: no reduction
459011 - Databus
U1121 00 [008] - Missing Message
[Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Date: 2000.00.00
Time: 00:00:00
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 2Q0 937 090 C HW: 2Q0 937 090 C
Component: BCM A0 Std+ H11 0943
Serial number: 00102032901570
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_BCMA0 206001
ROD: EV_BCMA0_206_VN46.rod
VCID: 323D1754F4A6334B2D6-8067
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 559 C HW: 5Q0 955 559 C Labels: 5Q0-955-547.CLB
Component: RLS 054 0206
Serial number: S5Y20M11D12H00M03S46
Coding: 0018EE
Driver door control module:
Subsystem 2 - Part No SW: 7L1 959 405 B HW: 7L1 959 163 B
Component: FHSG_DRV 001 0002
Serial number: 00000000000045345199
Coding: 1F000F
Front passenger door control module:
Subsystem 3 - Part No SW: 7L1 959 406 B HW: 7L1 959 164 B
Component: FHSG_PSG 001 0002
Serial number: 00000000000044534061
Coding: 050007
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY202901VKQ
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000048909261
6 Faults Found:
132619 - Voltage Supply; Terminal 30; Right
B140E 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Mileage: 7545 km
Date: 2022.11.09
Time: 14:50:17
Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
Zusaetzliche Umgebungsdaten-Low beam: Not operated
Zusaetzliche Umgebungsdaten-OFF: Not operated
Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
Zusaetzliche Umgebungsdaten-Position lamps: Not operated
Zusaetzliche Umgebungsdaten-Parking light left: Not operated
Zusaetzliche Umgebungsdaten-Parking light right: Not operated
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 11.7 V
134411 - Voltage Supply for Terminal 30 of Front Wipers
B1899 13 [008] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Mileage: 7545 km
Date: 2022.11.09
Time: 14:50:14
Zusaetzliche Umgebungsdaten-voltage measurement: 11.6 V
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
B131D F7 [008] - No Release by Immobilizer
[Kommunikationsüberwachung Kombiinstrument zum BCM(Fehler DWA)]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
Zusaetzliche Umgebungsdaten-Terminal 15 status: On
Zusaetzliche Umgebungsdaten-voltage measurement: 11.0 V
264452 - No Communications with Anti-Theft Sensor
U10F4 00 [008] - -
[Sensor-DWA->kein Signal/ Kommunikation]
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 166
Mileage: 7545 km
Date: 2022.11.16
Time: 16:28:18
558869 - Databus
[Kombi_01 Datenbus fehlende Botschaft]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
Zusaetzliche Umgebungsdaten-voltage measurement: 10.8 V
919560 - Light Switch
B126A 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Mileage: 7545 km
Date: 2022.11.09
Time: 13:55:15
Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: OFF
Zusaetzliche Umgebungsdaten-voltage measurement: 11.8 V
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5QA 919 294 J HW: 5QA 919 294
Component: PDC 8 Kanal H08 0073
Serial number: 000150058320328
Coding: 8451051801
ASAM Dataset: EV_EPHVA18AU3700000 009053
ROD: EV_EPHVA18AU3700000_AU27.rod
VCID: 53F372D0AB7C1A43060-8007
6 Faults Found:
12670210 - Databus
[Steuergerät für Schalttafeleinsatz-J285 - Kombi_02 - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
13637408 - Databus
[Bremsensteuergerät - ESP_02.ESP_Gierrate - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
13637419 - Databus
[Bremsensteuergerät - ESP_02.ESP_Laengsbeschl - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
12670240 - Databus
[Steuergerät für Schalttafeleinsatz-J285 - Gateway_72.WFS_01_alt - kein Signal/keine Kommunikation]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
13637426 - Databus
[ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
13636864 - Databus
[Dimmung - Dimmung_01.DI_KL_58xd - Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 R HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0372
Coding: 2A00600201FF8748949C815560508700000000000000000004
Shop #: WSC 00012 790 00017
ASAM Dataset: EV_ACCMRRCONTIVW376 003016
ROD: EV_ACCMRRCONTIVW376_003.rod
VCID: 43D342905B1C8AC3B60-8017
10 Faults Found:
1080 - Databus
[FAULT_TIMEOUT_KOMBI_01]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 15: 10.9 V
Control Module temperature: 11 °C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.47 m/s²
Adaptive distance regulation: status: ACC_Init
1227 - Databus
[FAULT_TIMEOUT_KOMBI_03]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 15: 10.8 V
Control Module temperature: 12 °C
Longitudinal acceleration: 0.00 m/s²
Adaptive distance regulation: status: ACC_irreversible error
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
Adaptive distance regulation: status: ACC_StandBy
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
Adaptive distance regulation: status: ACC_reversible_error
0822 - Databus
[FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
0828 - Databus
[FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
Voltage terminal 15: 10.7 V
0855 - Databus
[FAULT_EGO_FZG_GIERRATE]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
0854 - Databus
[FAULT_EGO_FZG_LAENGSBESCHLEUNIGUNG]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 166
Date: 2000.00.00
Time: 00:00:00
Saturday,19,November,2022,21:29:45:38189
www.Ross-Tech.com
VIN: WV1ZZZ7HZMH054892 License Plate: 21:29
Scan: 01 03 08 09 10 13 15 17 19 20 44 5F 75
01-Engine -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
20-High Beam Assist. -- Status: Cannot be reached 0100
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Revision: 23301001
Readiness: N/A
1 Fault Found:
B10CD 00 [009] - -
[Funktionseinschr‰nkung durch Energiemanagement Ruhestrom]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 7544 km
Date: 2022.11.18
Time: 05:09:16
Voltage terminal 30: 12.3 V
Coding: 0018EE
Coding: 1F000F
Coding: 050007
Alarm horn:
Coding: 8451051801
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 2Q0 959 655 AD HW: 2Q0 959 655 AD
Component: VW22Airbag 016 0506
Revision: --------
Coding: 8800C00000000000400000CF008C40000065
ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
ROD: EV_AirbaVW22BPAVW27X.rod
VCID: 7F5B0E6077742E23928-802B
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI3
Part No SW: 7LA 920 941 A HW: 7LA 920 941 A
Component: KOMBI 202 8400
Coding: 27A40A002480260001882A010401000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009071
ROD: EV_DashBoardVDDMQBAB_VW27.rod
VCID: 3E25336430FEE72BD9E-806B
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AG HW: 3Q0 907 530 C
Component: GW MQB High 521 5423
Serial number: 28112010522144
Coding: 030100044F05730000000058000F00010001070000000000000000000000
GVL: 01443C0000000100400080008000480000000000000000000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
VCID: 74B1D14C4E327D7BFFA-8021
Generator:
Component: 5-00-11-00-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 3G0 959 442 N HW: 3G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H07 0110
Serial number: PR6-0440071333204452
Coding: 2C0D00
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 7E0 915 181 N HW: 7E0 915 181 N
Component: J367-BDMConti H03 1052
Serial number: 7734330100201126044F
2 Faults Found:
131632 - High Beam Assistant Control Module
U1070 00 [009] - No Communication
[Timeout Knoten 0x30 / 20 - Steuerger‰t f¸r Fernlichtassistent]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 7544 km
Date: 2022.11.18
Time: 05:08:43
Terminal 30 power supply: 12.1 V
Terminal 15: On
8526361 - LV Energy Management
B1802 F1 [009] - Warning Triggered
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 126
Mileage: 7544 km
Date: 2022.11.18
Time: 05:08:43
Terminal 15: On
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 0000000000000000000000
ASAM Dataset: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2E050324E09E17AB49E-807B
6 Faults Found:
13238273 - Databus
U1121 00 [009] - Missing Message
[ECU for steering wheel electronics: no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
Communication status of data bus 1-ABS Control Module: No communication
Communication status of data bus 1-Data Bus On Board Diagnostic Interface: No communication
Communication status of data bus 1-Engine Control Module: No communication
Communication status of data bus 1-Vehicle Electrical System Control Module: No communication
Communication status of data bus 1-Steering column electronic systems control module: No communication
13238274 - Databus
[Diagnostic interface for data bus (Gateway): no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
13238275 - Databus
[ECU for engine: no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
13238276 - Databus
[Break-ECU: no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
13238277 - Databus
[ECU for power supply: no signal/no communication]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
15466752 - Control module not coded
U1013 00 [009] - -
[ECU not coded]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 0
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 7LA 909 144 F HW: 7LA 909 144 D
Component: EPS_MQB_ZFLS 751 7150
Coding: 0106
ASAM Dataset: EV_SteerAssisMNB 002012
ROD: EV_SteerAssisMNB.rod
VCID: 45D75C885528B4F3984-8011
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 3CN 035 869 A HW: 3CN 035 869 A
Component: MU-E-D-ER 720 0890
Serial number: 04122000022583
Coding: 066401003C00000041110101008000001F0000C60000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001044
ROD: EV_MUEnt4CGen2LGE_VW27.rod
VCID: 44D1418C5E128DFB8FA-8011
Address 75: Telematics (J949) Labels:* None
Part No SW: 5WA 035 282 HW: 5WA 035 282
Component: OCUGen3Low H14 0083
Serial number: 0000000008NVDN2
Coding: 06462000196818208005460160000607
ASAM Dataset: EV_OCUGen3Low 002036
ROD: EV_OCUGen3Low_002_VW27.rod
VCID: 015F8898018058D3E4C-8055
1 Fault Found:
7170 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Multi Function Display (0x0F) - Funktionseinschr‰nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 40
Mileage: 7544 km
Date: 2022.11.18
Time: 05:08:46
Voltage terminal 30: 12.1 V
End----------(Elapsed Time: 01:24, VBatt start/end: 12.4V/12.3V)-----------
EDIT: posting was scrambled inside the quoteThanks for that link, mmi.
Here's the latest AutoScan - and as you suggested, clearing the DTCs removed most of the errors.
As it happens, I did connect the two camera wires to pins 7 and 17 of the Can gateway (soldered to the wires near the gateway plug) and tried to activate the HBA module through the software. I probably didn't do it correctly OR didn't wire it correctly, but whatever, it shows up un the latest AutoScan - here:
Revision: AA001001
6 Faults Found:
13238273 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
13238274 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
13238275 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
13238276 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
13238277 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 0
U1013 00 [009] - -
[ECU not coded]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 0
