Vcds scan red underlined parameters??? No fault codes?
Dm85
Hi all,
I’ve noticed looking at past scans on my computer there’s red underlined sections. There are no fault codes but is it indicating these are out of specified parameters?
Or nothing to be worried about?
Cam shaft drift angle
Tandem fuel pump
Isn’t that the windows spell-check type thing telling you that they are misspelled and if you click them you get an alternative? Not sure it’s anything to do with vcds.
Ahhh, thank you! Makes sense now! I just opened the logs to check through and thought what is that.
