I thought I couldn't find it .The map is no longer available.
Hi,VCDS HEX2 unlimited VIN's
South Wales
Hope this helps!
Yes, PenarthHi,
You in the Cardiff area?
Yes, I have Discover head unit in my Tiguan and I did someones rear speakers here earlier in the year.I’m in penarth too. Do you know how to add rear speakers and fader to Vw head unit? got a quote for speaker and amp upgrade from Absolute5 but said I need I need the latest VCDS. not found local audio fitter that helpful?
He had white multidot display so i also enabled digital MPH as well for him.
Cheers, thank youI have been using VCDS for years ON VW's and Skoda's
Just PM me when you want it done
I'm in Sidmouth - EX10 - if you get stuck. Looks to be 115+ miles from Cardiff so I'd hope you find someone nearerHello all,
Looking for someone to program my toe bar electrics. Happy to travel and happy to pay cash, beers etc. I live near Cardiff. Any help would be much appreciated
VW T6 2018
@welshkaiboy may be able to help you outHello all,
VW T6 2018
I am in Penarth and can help you. PM me what module you have fitted and then we can sort it for you no issue.Hello all,
VW T6 2018
Yeah sure, I can take a look. Whereabouts are you?@welshkaiboy would you be able to do some coding for me please? I've fitted some new rear lights and they are throwing a bulb error.
Your profile won’t allow PM’s mateYeah sure, I can take a look. Whereabouts are you?
What lights have you fitted?
PM me if you want
yeah that's simple in VCDS. I can do any other coding for you at the same time depending on what you got fitted.Your profile won’t allow PM’s mate
I’m in Cwmbran and the lights I got from Transporter HQ……they sent me a link to a video of what needs to be done.
How To Code T6 Transporter headlights | Vagcom & Carista | Transporter HQ - VCDS
You could try @LightrofitGot a potential issue with reverse parking sensors. Sometimes when I go into reverse the display shows full range of central sensor pair (the graph that fills up as you get close to something). But more often than not I just get the closet 3 levels displayed only and the nearest block is solid red. I think it’s possibly a connection issue but hoping an OBS diag would tell me.
Where abouts are you located?Got a potential issue with reverse parking sensors. Sometimes when I go into reverse the display shows full range of central sensor pair (the graph that fills up as you get close to something). But more often than not I just get the closet 3 levels displayed only and the nearest block is solid red. I think it’s possibly a connection issue but hoping an OBS diag would tell me.
