Warning light on dash after fitting new wheels
Seeking some advise on a new feature to me, Tyre monitoring light came on dash. Tyres set to right psi, but I can not work out now the monitoring system. (I do not have MFS) On the dash I get up message reset tyres and press OK but can not work on where to OK it Can not see button in glove box.
Thanks in advance Andy
Using the trip buttons on the dash you need to go to settings and tyre pressure then press the other button as if you are entering the menu option and then next time you drive the system learns the new rolling radius.
Thanks Loz got there in the end
If you are driving in different road conditions or your style of driving is different to your usual then this can set the tyre pressure light off. Happened to me in my 2014 golf I had. As I hadn't driven her at speed on a country road before it came on. Stopped at petrol station and all tyre pressures were spot on. Reset and didn't come on again but in the manual it said about driving style and conditions being a contributor.
I know you are taking wheels off etc but just thought I would share.
Just push the re set button in the glove box until it Bing's ,it has detected a change in wheel size .
. AHHHHHHHHH sorry please help. Where is this reset button in the glove box. All I can see in my glove box is a black square that does diddly. I can only assume it’s meant to be there ?
No it just resets the TPMS, it stores the rolling speed of each wheel in relation to each other and warns you if one goes out of sync ie a flat tyre
