Turbotricky
That’s a relief, thank you guys for the quick response!! Amazing forum
ThanksVW recommend the AC is run at all times, remember not to use the fan setting 1, it tends to burn out the resistor pack.
does this effect fuel consumption or is this a myth?VW recommend the AC is run at all times, remember not to use the fan setting 1, it tends to burn out the resistor pack.
I was once told that using air-con was more efficient than the drag coefficient that having a window open causes.Modern aircon systems are much more efficient than the early systems. Yes, they are bound to use more fuel, but I haven’t noticed a difference.
Pete
ThanksWhat he said . . .![]()
