Saturday,22,March,2025,19:18:04:12236
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 25.3.0.4 (x64) HEX-V2 CB: 0.4660.4
Data version: 20250311 DS365.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZGH121311 License Plate:
Mileage: 268180km-166639mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 13 15 17 18 19 22 25 5F 61 69 6E 0B
VIN: WV1ZZZ7HZGH121311 Mileage: 268180km-166639miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KK HW: 04L 907 445
Component: R4 2.0l TDI H02 3803
Revision: 23002001
Coding: 0019401C433601090000
Shop #: WSC 27577 001 1048576
ASAM Dataset: EV_ECM20TDI03004L906056KK 004005
ROD: EV_ECM20TDI03004L906056JT.rod
VCID: 005996365A81FFCA8F7-8054
VINID: 9E606AAAA1D8A976010810C1047F8B6DA9
No fault code found.
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 40676000001447
Coding: 557EC0982564847FAA780377A48321A678F100
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB55CA67FF4032B6D-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 26011613470678
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5E8CE2075893AFDB-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AK HW: 7E0 907 047 AK
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis_VN75.rod
VCID: 73B3C9FA1B37D452825-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 070160628
Coding: 22A0303A0A6134B393284F747CEB8E748FB4688F60CC6960320400A20840
Shop #: WSC 02737 534 205768
VCID: 6889AE965271278A277-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 090316 03 37 0059
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 H HW: 7E0 959 801 H Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU016031660763825
Coding: 0400A0
Subsystem 3 - Part No SW: 7E0 959 802 H HW: 7E0 959 802 H Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU016031660767288
Coding: 1400A0
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29160000450700056091
Coding: B0FFFF
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 R HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0210
Revision: -------- Serial number: 32931602506373
Coding: 11800A
ASAM Dataset: EV_VW75XParkAssis4K 001012
ROD: EV_VW75XParkAssis4K_001_VN75.rod
VCID: 41DF5332110B36C2C09-8014
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 A HW: 7E0 907 572
Component: ACC Bosch PQx H03 0110
Serial number: 14031677110885 Dataset Number: 7E0114v____ 0009
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001004
ROD: EV_ACCBEGVW361.rod
VCID: 34310AE65EB9936A5BF-8060
2 Faults Found:
1540 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
C1103 00 [00001001] - -
[FAULT_MISALIGNMENT_HORIZONTAL]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 268137 km
Date: 2025.03.15.
Time: 11:14:27
Control Module temperature: 15 C
Voltage terminal 15: 12.2 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s
1541 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
[FAULT_MISALIGNMENT_VERTICAL]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 268137 km
Date: 2025.03.15.
Time: 11:14:27
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag01L H08 0018
Revision: -------- Serial number: 003V300078EN Dataset Number: 7E0003V____ 0841
Coding: 00000000000000000000000000000000314C
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2D24DE7CDD651A813-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 870 L HW: 7E0 920 870 L
Component: KOMBI H05 1008
Serial number: 00000000000000
Coding: 160B010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
VCID: 323D0CFEA4AD9D5A493-8066
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 272 B HW: 7E0 963 272 B
Component: STH-T5GP2 003 0009
Coding: 4C01
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B03119A8387CC920A5-807E
1 Fault Found:
0353 - Comfort System CAN Bus (SAE Medium Speed Bus)
U0011 00 [00001000] - Performance
[CAN KOMFORT GLOBAL TIMEOUT]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 85
Mileage: 268188 km
Parking heater: operating condition: OFF
71
Coolant temperature of parking heater: 15 C
Coolant temperature: -48 C
Engine running status: not detected
Fuel level: 29 l
Heating performance: 0 W
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042207
Address 22: AWD (J492) Labels:| 0CQ-907-554-V1.clb
Part No SW: 0AY 907 554 L HW: 0CQ 525 130 A
Component: Haldex4Motion H53 7620
Serial number: HA1-00019.06.19 Dataset Number: v1260x015G0 0000
Coding: 3807
Shop #: WSC 99999 999 83333
ASAM Dataset: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X_002_VW36.rod
VCID: 54F16A66FE79B36A7BF-8000
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1008
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: 6A8DD49E4CFD159A313-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H22 0245
Serial number: VWZAZ2S8310028 Dataset Number: V03935240VJ 0001
Coding: 065700013C00000011111101008808001F0100C4002001004F
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 211FF3B2F14B16C2A09-8074
Data carrier:
Subsystem 1 - Part No SW: V03 959 821 FN HW: -----------
Component: ECE DL2 24/25 --- 2210
Serial number: --------------------
1 Fault Found:
2562 - Navigation System
B126C F0 [00001000] - Navigation Database Faulty
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 83
Mileage: 268168 km
Date: 2025.03.19.
Time: 16:44:10
Voltage terminal 30: 12.7 V
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 330B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 63062N24031261673606
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 4
Reset counter: 85
Mileage: 268151 km
Time Indication: 0
Date: 2019.08.06.
Time: 22:59:46
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 H HW: 1K0 907 383 G
Component: Anhaenger H12 0130
Revision: 3B001001 Serial number: 00000397787520
Coding: 410D000103000000
VCID: 323D0CFEA42D9D5A493-8066
Address 6E: Ctrl Head Roof (J702) Labels:. 7E5-919-037-W2.clb
Part No SW: 7E5 919 037 G HW: 7E5 919 037 G
Component: Dachdisplay H15 0185
Revision: 10100011 Serial number: 421888
Coding: 000102
Shop #: WSC 02759 790 00000
VCID: 353737E255438A626C1-8060
End----(Elapsed Time: 02:01, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
------------------------------5 Faults Found-------------------------------
