I’ve varied the temp, but even in the early + range I’ve got ice.You had a tube? Did you have installation instructions?
The drain doesn’t drain water away so maybe its a redundant design functoon left in place but not in use?
Mine ices up quickly too then eventually thaws but the resulting water pools in the bottom. What temp are you operating at?
Query sent, there's no literature on their website either..
I am hoping I can adapt it to run off 240V as well (when on hook up or at home for precooling) and think I can just change the controller out for the 101N0510 controller (at an eye watering £236)
Nope, no reply or acknowledgement of inquiry.
Bump.Query sent, there's no literature on their website either..
Via the retailer I managed to get a new switch plate and ribbon cable delivered. Penguin refrigeration (I think, Distributor) offered to talk me through the part replacement on the phone, so I took the opportunity to ask about the “drain” Hole and pipe configuration.Bump.
I bought one of these last year (October) and wondered the same about the drain. Any updates on longer term use with the drain pipe “as delivered”? I haven’t taken mine out of the cabinet since installation and the drain pipe is not accessible.
If you’ve got a EHU with leisure battery charger then you shouldn’t need the extra mains controller.
On mine the “night mode” has stopped working. Which is disappointing as it does make a difference to the noise generated by the compressor. Given the lack of customer support from the manufacturer I had better contact the supplier.
I had considered the 240v controller option but discounted it.I managed to find a 12/240 controller cheap in the states, picked it up while I was there in May. Not fitted it yet. I've had no issues with running the fridge off 12v so far, any drain on the leisure battery has been replaced by the 200W solar panel before I get my lazy arse out of bed most days, I have it on at the moment 24/7 letting the solar do its thing and keeping a few beers cold (thanks Paynewright) to see if it will do extended off grid duty.
As It's not in its final resting place yet (currently sitting in a home made box so it is usable) it still has the tube looped but I will be extending it to drain outside when it goes into position in the units.
Understood. Cheers for the replyThe fridge is the most power hungry item in the van, and it's on all the time I'm away. The ability to have it be powered off mains when it's available is a plus for me, I don't have a mains battery charger for leisure battery, just solar or DC-DC when the engine is running.
