Westfalia T6.1 Trailer Wing Kit - Understand Instructions
HossP
Howd
Can anyone decipher what these instructions mean? See attached PDF.
I know how to Depin but this seems over simplified to me.
I have added some photos of the connectors.
Hoss
  • westfalia t6 wiring .pdf
It is simple as looks like a basic switched bypass kit than a full canbus kit.
I think first diagram with the eye is simply "if you have a blank plug in the frame then throw it away before fitting ours"
The next set are what to do if you have parking sensors - if you don't (crossed out) then you're done just tuck the unused bypass kit connector away - if you do you need to do more connector shuffling to loop them through the bypass kit so they will turn off when a trailer is connected.
