Delonghi Dedica
Best cup of coffee ever
The challenge is to get the flavours out of the beans into the water. Temperature, pressure, time, flow rate, water quality are variables to be controlled by the machine. It’s like turning diesel into a driving van.Excuse my ignorance, but I always thought the beans determined the quality of the drink. What role does the machine play in making a quality drink?
Very much so, but for an espresso machine the pressure, duration and temperature of the process is vital and some machines are better than others. Also vital is the grind size and how long ago it was done.Excuse my ignorance, but I always thought the beans determined the quality of the drink. What role does the machine play in making a quality drink?
Pods are quite expensive compared to using a ground coffee machine...but then again, I'm a tight Scotsmanany suggestions on a pod taking coffee machine that can make a good latte and also has a milk frother? Out of my depth here as a tea drinker and want to surprise her indoors (before I tell her how much the Clayton LPS cost )
Hi Jim, does your Dedica machine work ok without being on hook up? Thats the model I was looking at using in my camper.Delonghi Dedica
+1 for the Wacaco, perfect size for a bulging van…and the result is passable on an americano basis.Nespresso pods at home, so....
Tried a Nowpresso first; battery operated, but lasts forever if using the kettle to heat the water.
Nowxpresso – First Automatic Portable ESPRESSO MACHINE
Nowxpresso is the Ultimate Portable Espresso Machine that can boil water and make coffee for you wherever you are. Whether travelling, camping, in the car, office, hotel or home you can now experience coffee freedom with Nowxpresso!nowxpresso.com
One failed and we had it replaced under warranty; the pod press thing that punctures the foil cracked and so would not puncture it.
The second one has now bent and sometimes works, sometimes doesn't, especially on the denser pods. Shame, it was ideal, and would be great if they did a stronger, metal receiver.
Currently on a Wacaco Nanopresso with a NS nespresso adapter.
Wacaco | Nanopresso | Versatile Portable Espresso Maker
Packed with new features and capabilities, which will drastically improve the way you prepare your favorite coffee, Nanopresso is one of the best and most versatile portable espresso machines. A truly unique addition to your coffee toolkit!www.wacaco.com
Hand operated, which is a bit of a struggle with stronger pods, but works fine.
However the case has cracked, and is out of warranty. It is still working, but waiting for it to fail catastrophically.
Can't really justify the cost of lithium or a portable battery, unless I can convince Mrs CAB that we can Remoska off-grid!
The reciprocity I was referring to was @Radford1071s (a generous Scot) sending me Arthur Dozen wheel bolts and wouldn't take a penny toward his cost of sending them, or indeed the bolts! I'll send you this voltage checker, you could give it back at Bala if it's a one hit wonder!Reciprocation requires an exchange of some sort, be that ££, beer, tea... or even coffee
How about we cut out the PO/RM middlemen and exchange at Bala?
you can get a frother from Nespresso...we have one but not been used yet! (had it for over 2 years )any suggestions on a pod taking coffee machine that can make a good latte and also has a milk frother? Out of my depth here as a tea drinker and want to surprise her indoors (before I tell her how much the Clayton LPS cost )
Hi Rick. I plug it into my Ecoflow Delta 2 and it works OKHi Jim, does your Dedica machine work ok without being on hook up? Thats the model I was looking at using in my camper.
Rick.
And me....with a bit of coffeemate...Aeropress for me
I am a PG guy in my working day, but I will indulge in a black Nespresso coffee when the big boss isn't around. My colleague made me a black coffee yesterday with a spoonful of coffeemate in it. Absolutely foul stuff!And me....with a bit of coffeemate...
Gotta say our little Tassimo makes a good latte (the wife says). It's a 2 pod job, the second being the milky stuff. Obviously dreadful for the planet, but so is a diesel, rumour has it!any suggestions on a pod taking coffee machine that can make a good latte and also has a milk frother? Out of my depth here as a tea drinker and want to surprise her indoors (before I tell her how much the Clayton LPS cost )
A 100% chocolate drink is my kind of coffee! SllluuurrrpppNot a coffee machine, but we use a Hotel chocolate velvetiser in the van, runs at about 450w for 3 minutes a cup, we use a power bank at the moment, you can get various ‘coffee’hot chocolates along with the normal hot chocolates.
Highly recommended for a nice hot treat.
