I‘be seen there is a screw inside the tray at the back. Remove this and use a trim tool?It pulls up from the front nearest to you easy with a trim tool
That’s a really good job!Painted the battery cover on my T6. Blown away with his good it has come up.
Not bad for my first proper, not Buzzweld, spray job
Where are your mud flaps from pal ?Not just today, but over the last week or so.... replaced the Auxiliary belt and tensioner to get rid of the irritating squeaks, fitted carbon fibre grill trims (to cover up the previous red), fitted new mud flaps that look like they will actually do a much better job than the genuine VW shite things, removed my chrome sidebars, had tyres fitted to my new banded steels, fitted the wheels, then gave him a bath!
View attachment 98984View attachment 98985View attachment 98986View attachment 98987
Hopefully this’ll work.... I’ll try to attach a link?Where are your mud flaps from pal ?
Can you show a pic of where you fixed them?It worked.... @ChrisR has these on his van and kindly passed on the link to me. They’re great and very easy to fix to the plastic arch liner of your van. They come with fixings and actually fit where mud flaps should, rather than too far back like the genuine VW ones.![]()
I should’ve done that @JOG when I had the wheels off, but to be honest I was pushed for time yesterday when I was fitting them and losing daylight! I’ll get some pictures up ASAP. I used four fixings on each of the fronts and only three on each of the rears.... very easy job, but obviously a lot easier with the wheel off. I used an 8mm drill bit through the mud flap straight into the arch liner to create the hole for the fixingsCan you show a pic of where you fixed them?
No probs @T6ARF - whenever works for you is fine. Boris tells me I’m in no hurry as I’m going nowhere! ) It’s just that I washed my van today and can actually find my arch liners now!I should’ve done that @JOG when I had the wheels off, but to be honest I was pushed for time yesterday when I was fitting them and losing daylight! I’ll get some pictures up ASAP. I used four fixings on each of the fronts and only three on each of the rears.... very easy job, but obviously a lot easier with the wheel off. I used an 8mm drill bit through the mud flap straight into the arch liner to create the hole for the fixings![]()
About bloody time you had a SOS image @JOGTrue and then SWMBO refuses to go near it!
@moomin-j @Texxaco and @Niknak - oh ye of little faith!!!
First, I had to clean my caravan: View attachment 99003
No point having kids unless they earn their keep, eh:
Then do the van so we end up with:
Winter coat time:
And ..... my first ever entry for “Side on Sunday”!!View attachment 99007
I’d recommend removing each wheel in turn, so that you can get your drill in straightI still haven't got around to fitting mine, I'm assuming it's going to be impossible to do the rears without removing the wheels.
I’ll get a picture up for you as soon as I can mateWhen you get a chance @T6ARF can you take a pic of the MG from the rear please? Want to see how far they protrude from the van
Cheers buddy
Not pre drilled mate, so the world is your oyster!Agh ok, I thought l the holes were pre drilled @T6ARF
I have the genuine VW ones and they are only good for show. Another upgrade for the list.
Or, your arch liners are soon to be colanders!Not pre drilled mate, so the world is your oyster!![]()
Ordered just now!Hopefully this’ll work.... I’ll try to attach a link?
