Best £20 you'll spendHeko wind deflectors fitted.
really? mine are perfect. I like the fact you can have the window slightly open without if flapping aroundMine whistle like a bitch?
Went out to finish silent coating the tailgate.
Found this:
On the white clip you can see a stain where the water has run down. (I think)
I have taken the bolt out of the roof bar above, letting it dry in the hole a bit then will fill with clear silicon sealant and put the bolts back before it sets. Hope this well make it water tight.
Also found some more water in the tailgate. Will speak to a dealer this week. Hopefully its the light and they will replace it.
Who fitted the roof bars ? I think that white clip is the one that holds the captive nut that the roof bar bolt goes into.
Pete
Feel your pain fella roof bars absolutely ruined me last velleWent out to finish silent coating the tailgate.
Found this:
I knew I’d seen this somewhere @Skyliner33 was going to do this to my last velle but ended up getting rid, I think it would be the best solution to fix the leaky rails
Roof Rail Leak Free Fixing.
The design of them are absolutely pants.
Spent the day with the spray glue and carpet.
Fitted the under-seat draw unit built by @Captain Backfire. Just got to floss line it, and fit a kick trim along the bottom once it arrives, but it slots under the rear double absolutely perfect, and makes good use of that wasted space. Well chuffed with the result, thanks Ant
Got a little carried away with the extra carpet and covered all my side shelving.
