Moved on from panda pop cause the mess it makes if you get a pressure build up is ridiculousI been using the other brand Pepsi big gulp for ages
I find that intermittent, irregular stomping on the anchors when she has a full bladder removed any debate regarding where she can go....she just has to go and sod any witnesses!!! Seat belts are more than a safety feature, eh?!!Mrs Sackmycook wasnt impressed with my toilet tent and Thetford 165 purchase today, so I would be pushing my luck suggesting a contraption like these no matter how practical.....
Just pee in it....you don’t need to mount it!Moved on from panda pop cause the mess it makes if you get a pressure build up is ridiculous
Yeah but you know don’t you, you’ve tried it tooJust pee in it....you don’t need to mount it!
Yep, and you’re right, the pressure does build up! All depends on how much you fill it, I suppose!!!Yeah but you know don’t you, you’ve tried it too
Nothing worse than a soggy coneView attachment 112163
Hope I've solved the wet step and speaker problem, since I upgraded the speakers. With Thanks to @Absolut5 and @Dellmassive
Or a wet rimNothing worse than a soggy cone
No, no issues with a dripping rim - a quick wipe sorts that!Or a wet rim
4 way stretch carpet. Used Trim Fix spray hi temp. adhesive.Looks great. What did you cover it with?
Hi there, just watch the front door doesn’t rub on the top of the mudflap. Can take the paint off and rust over time. Try sanding/ cutting the top part away if it rubs.Mud flaps fitted. Just concerned now I won't splash enough puddle water up the side of the van to clean it!
View attachment 112105View attachment 112106View attachment 112107View attachment 112108
Nice Garage / Ramp setup there . . . .Just got my calipers painted, frontspoiler mounted and now waiting for summerwheels to be fitted on the vanView attachment 112188View attachment 112189View attachment 112191View attachment 112190
What panels have you used? I'm still on the hunt for some for mine!
I got the whole lot from Plyworx, not the cheapest panels out there but they do fit really well and have a quick order time.What panels have you used? I'm still on the hunt for some for mine!
