Hello,@Dieseldonkey the 300w panel was too big for the ablemail 12-12-30 with the solar connection so i was advised to use a seperate victron and buy the ablemail without the solar connection
Ah ok. Thats got me checking the spec for the 121230. All I can find is its suitable for panels greater than 100 watts and needs 18 volts from the panel to initiate solar charging. Assuming 100 efficiency, 300 watts at just 13 volts is only 23 amps output, so seems well within its capabilities. Unless I'm missing something.
I run a 160 watt panel through mine and get a charging profile like this during day light hours on sunny day. The voltage I've used for calculating above is on the low side to allow for a maximum current.
