hi have these two as a direct comparison.
Shed Solar
photonic universe - 2x150w EFLXRJB-150M
Vmp 25.5v
Voc 30.1v
Imp 5.88a
Isc 6.35A
Dims 1445*540*3mm
150W Semi-flexible Solar Panel with Round Rear Junction Box and 3m cable, with durable ETFE coating (Back-contact solar cells)
Renogy 160W RNG-160DB-H
Renogy 160 Watt 12 Volt Flexible Monocrystalline Solar Panel
Flex Mono
Maximum Power at STC*: 160 W
Cell Efficiency: 21.0%
Optimum Operating Voltage (Vmp): 19.1 V
Optimum Operating Current (Imp): 8.38A
Open-Circuit voltage (Voc): 23 V
Short-Circuit Current (Isc): 8.88A
Maximum System Voltage: 600 VDC
Maximum Series Fuse Rating: 20 A
Output wise they are very similar. The PU has slightly higher VOC, the RGY has slightly higher ISC but they bothe roughly ballence out.
I've had all 3 running together with no issues.,
heres todays data, it shows the panels are generating 70V from 8am till about 3pm ( the batteries are basically always 98% fully charged which is why the current is shown so low).
and this is the last 6mnths data:
which is ample to keep the 2x 110Ah Extreme SLA batteries charged (which run the shed and garden LEDS and stuff)
The only real difference seems to be with the build quality . . . .
The RGY panel is slightly thinner and seems to have been effected by the summer weather (heat) . . . .
the panel seems to have developed a slight dishing/cupping around each cell, its difficult to see from the pics. But its almost like the backing has warped and twisted a bit.
Im assuming its where the cells have got hot and being as they are stuck on the roof the heat has warped the backing somehow.
RGY PANEL below (outside 24/7) :
and PU panels below (outside 24/7) :
(i sprayed the edges black so they didnt stand out so much):
The PU panels are as good as the day they were fitted.....
The dimpled top layer seem to work well catching all the light they can on both sets of panels.
The Renogy Mobile suitcase and fold-out mobile panels are also as good as new, though they are only out when needed then packed away . . . .
So going by the above id say output wise the are very similar, but quality wise the PU is slightly better at withstanding the elements.
Remember Renogy and PU just buy in other manufactures panels and put there own sticker on them - they dont make them themselves. so you need to look at the panels on a case by case basis . . . .
so over all i would still generally recommend Renogy, PhotonicUniverse & Lensun,
out of the two shown above id chose the PU one as a recommendation
This specific panel (which is again different to the ones above)
VAN: Solar Panel: PhotonicUniverse EFLXRJB-160M 160W 12V ETFE Black Flexible Solar Panel (not fitted yet)
What Solar Panel/controller, Dc-dc, Leisure Battery - Have You Got ?
is still boxed in the shed waiting to be fitted on the van roof - but again you can see it is of a different construction ( possibly a different manufacturer)
