Wheels size
oguzhano55
IMG_0850.jpegHi everyone I’m Oguzhan,
I find for my T6 18’’ wheels. This is the rim I want bmw style 397 and 255/45/R18 tire. That rim specs
8Jx18 5x120 ET34. Will the rims overflow from the car when I wear these bodies?
View attachment 276639Hi everyone I’m Oguzhan,
Hi oguzhano55 and welcome to the T6 Forum. i am sure someone on here can specifically answer your question. :)
Wow, thank you. It looks nice, but why do I need spigot rings? Would it be dangerous if I wear it without that piece?
The BMW wheels will have a centre bore of 74.1mm - the T6 has 65.1mm.
Spigot rings stop/reduce vibrations and a few other issues - don't drive without them.
Yes, you'll find different opinions online but for £10 just don't risk anything.
In theory the wheels hold onto the hub with the axial clamping force of the bolts but...
Spigot ring will ensure a good fit between the wheel and the hub - without, you could get severe vibrations, uneven trye wear and wheel bolts could loosen.
Did you check the load rating? From what I can find out it is 91, this is not high enough for a transporter. Only rated to 615kg
I did some research and read that even if I use a spigot rings, vibration may occur at high speeds. I'm thinking of not installing this rim, I will consider the original 18'' rims. Thank you for your suggestions.
Welcome to the Forum. I don't know if all of them will be available in your region, but there are lots of ideas for 18" wheels in this thread.
Welcome to the Forum. I don't know if all of them will be available in your region, but there are lot's of ideas for 18" wheels in this thread.
Thank you so much.
