Ignore that, it actually does sweep each time I turn the ignition on.
Adjusts the sensitivity of the auto wipersBut annoyed that my intermittent wipers didn't work, moving the switch to fast and slow doesn't do anything. Then I went passed a truck and got loads of spray and my wipers went manic, turns out it has rain sensors!
So, do they all have rain sensors if so what's the fast/ slow intermittent switch for?
Deadlocks(safelock), 2 pulls on any handle will open the door.Discovered the other day by accident. Press the lock all doors button need to press unlock to get out? If you double pull the door handle it unlocks drivers door only and leaves rest locked.
Deadlock, lock(no deadlock),unlock,deadlockI was in mine today fitting the tambour doors to the units with my key in my pocket and must have pressed something because both the front windows came down
What would 4 presses on lock do? and I am not joking
except we only have a single offside rear fog light in the UKFront fog lights come on singly - either right or left when turning.
When in reverse, you can get similar thing to happen on the rear fogs by manually turning on the fog light switch, then you will get one rear fog light on singly - either right or left - to give a bit more light when reversing.
