You wouldn't want it any darker or you'd have a massive blind spotCheers. The code on the box is 3277D which on the Climair website says it’s the Dark Sports version so I guess it isn’t a true, opaque black in an inverse Spinal Tap type way
But if that means that the van goes up to 11... so much the betterCheers. The code on the box is 3277D which on the Climair website says it’s the Dark Sports version so I guess it isn’t a true, opaque black in an inverse Spinal Tap type way
I recently posted photos of the smoke vs dark ClimAir which may help you clarify what you have received.I’ve just been bought some Climairs as a Father’s Day present in black but they don’t look as opaque as I’d expected as you can see through them. Can anyone confirm that this is how the black ones are i.e. not completely black and slightly see through?
Thanks for posting the image and linking to the other thread. Now feel way more confident that the correct colour was delivered!I recently posted photos of the smoke vs dark ClimAir which may help you clarify what you have received.
ClimAir wind deflectors
Sorry to resurrect an older thread but I really benefitted from the discussions and thought I could add further value which in turn could help others with their own decisions. Having researched wind deflectors on this forum, I settled on the ClimAir brand but couldn't decide between black and...www.t6forum.com
I also took the following comparison photo which I haven't previously uploaded. (my dark ones have 'Sport' written at one end.
Clim AirAny wind deflector recommendations for a T6? There seem to be lots of different versions…..
Checked the Climair website. Says you need to drill a hole to fit. I had assumed they would clip in….?
+1 for Climair -+1 for climair, the hole is tiny (1mm i believe but would need to double check) I wouldnt worry about it!
Wind deflectors - my comparison.
I have see quite a few posts on wind deflectors, so thought I would my thoughts. I have now had 3 different types so maybe can help others with a choice. The ones I have used (in the order I used them), with pros and cons are: 1. VW OEM: These stick on the outside onto the painted surface of...www.t6forum.com
Another for Heko - didn't want to drill a small hole. I did use some extra clips from E Bay and everything is secure 18 months on.+1 Heko
Where did you get them from please, would rather go direct to a seller that a forum member has experience of.Heko for me too on out T6.1![]()
They definitely look darker than my non-black (can’t remember what they call it) climair deflectors. As above, vision would be hideously obscured with solid black. Remember my first drive in a T5 - almost pulled out in front of a cyclist coming round a roundabout as they were hidden behind the blindspot of the A pillar. Thankfully I always look twice so no drama. That was my reason for picking the light smoke (maybe that’s the name of it!) version.Cheers. The code on the box is 3277D which on the Climair website says it’s the Dark Sports version so I guess it isn’t a true, opaque black in an inverse Spinal Tap type way
