started with slight exhaust smell.
then bad exhaust smell,
then exhaust smell coming via blowers,
then exhaust smell coming from everywhere. + slight hiss from under van.
then exhaust smell coming from everywhere. + slight loud hiss and blow from under van and engine bay.
Now loud hiss - very noticeable with slight accelerator blips (air blowing sound)
not fixed yet . . .
but I've added my case to the main thread on it . . .
you cant miss it . . it stinks and will start gassing you at first . - then after a while you will hear it.
Looking at the access its a pig of a job! I have the 204 engine so access isn't so easy Took me a whole day to do. Still not sure the bolts are quite tight enough but seems to be ok. My hands took a right beating. There’s something back there a bit lower down too that looked like the oil...
www.t6forum.com
As per the title really - T6 Common faults & problems - - Check here first - (ill keep this updated and as current possible, so keep checking back) we have a lot of repeat questions about the same issues again and again, so here is my attempt to group the more common ones into one place...
www.t6forum.com
