Would I face any issues increasing T5 rolling diameter by 2"?
Locovolataic
Gonna start by saying I'm a complete beginner when it comes to wheels and tyres, so please do correct me as I honestly find this whole topic a bit mad!
So, I believe a T5 with OEM wheels has a rolling diameter of 27". I was reading somewhere that if you change your wheels and / or tyres, then try to stay within 3% of this number to avoid messing up the vehicles speedo and possibly safety systems.
My 2008 T5 currently has the 17" Davenport alloys and some budget 215/60R17 tyres. I've been mathing and this gives me a rolling diameter of 27.2".
However, I want to put on some 235/65R17 tyres which would bump my rolling diameter up to 29" which is outside this 3% range.
So a few questions:
  1. What are going to be the effects of changing to a tyre by this much? Other than the speedo (which I can live with), will any other systems be affected? Bearing in mind this is a 2008 van, I'm not sure what "systems" it has to start with.
  2. Based on the above is there anything I can do to "fix" anything that is affected?
  3. I had a friend recently who's Transporter failed its MOT due to alloys, I thinkg they were 20". I've been meaning to ask him more about it, but haven't seen him yet. Just wondering if an increase like this would cause an MOT fail?
I am running the same Falken wildpeaks on Devonports having moved from the standard size. Zero issues other than now the speed underreads a little so I am actually going faster than the speedo shows which is technically illegal etc however I only ever use my satnav for GPS speed. Is it standard suspension if so then it shouldnt rub although I have spacers so cant comment for sure.
I had standard 16” on my T6 (205 65 16) just upgraded to 18’s running now conti all season 235 55 18,
Van stands about 2.5” taller.
No rubbing issues at all, no problem with MOT Speedo is slower than actual so when it shows 64mph on the clock that is 70mph… run with stand alone gps with speed showing
