Thanks - that might be where I'd go the idea that I had to use the key - away from tomorrow so I will have a play with it.The pillar button only works with the drivers door open, but once selected you can exit and lock from any door.
So that's three of us then. But the Aus market factor can't be the only reason cos mine is based on a German market T6 and so are Calis and I don't see any of them saying they don't have deadlocking. Or do all Calis come with volumetric alarm as standard, that would bear my other theory outI'm pretty sure i don't have dead lock either from reading this, ill have to check it.
It could just be that as Aus delivered VW, we don't get the dead lock, most likely due to ADR rules on escape.
not that I've looked into ADR rules on this issue, just a guess, or that VW australia are cheap
That is how it is supposed to work.My two pennies, thrown in:-
Now the real interesting one!!!!!!!
Fourth test. Open the window, press the key fob button once, get the double 'thunk' from the locking mechanism, now press the key fob lock button for a second time, you get a single 'thunk' from the lock. Now reach through to the interior door handle, pull it once and release and the door nob on the trailing edge of the door card pops up, pull the interior handle a 2nd time and the door opens!!!!
@Loz. Please do buddy. Happy to help anyway I can. If you need me to try any specific other combination in a test just drop me a line.That is how it is supposed to work.
I just rang a mate of mine with a new California and his is the same as mine...
I think I have a scan of yours @DaveyB from Bala so I am going to compare coding.....
Will do, thanks@andys if you pm me your reg & vin (as may not be a UK designated model) i can compare the part numbers on your locks to mine and see if i can spot any obvious differences ??
Agreed, but I was not expecting the B pillar button to do it as well.It has always been that way. One press to deadlock, second press releases deadlock.
