Thanks Snowy, Carista ordered.Hi I found mine out with carista, if your scanner has a live data setting click on that then when you take it for a drive it will give you speed of each individual wheel…. my right rear read at zero so I knew to change that one
ECU info obtained with Carista 750099 for iOS:
VIN: WV1ZZZ7HZHH065131
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Software version: 0744
ASAM/ODX identifier: [none]
Coding: 042305 (hex)
[No fault codes]
Engine
Part #: 04L906056KJ
Component: R4 2.0l TDI
Software version: 3770
ASAM/ODX identifier: EV_ECM20TDI03004L906056KJ
Coding: 00194014432701090000 (hex)
[No fault codes]
ABS
Part #: 7E0907379P
Component: ESC
Software version: 0133
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: 557E809825688483AA760179A48321A6790000 (hex)
Fault codes:
00079 Manufacturer-specific code
04197 Manufacturer-specific code
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: 01 (hex)
[No fault codes]
Airbags
Part #: 7E0959655G
Component: VW10Airbag021
Software version: 0018
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: 000000000000000000000000000000003231 (hex)
[No fault codes]
Instrument cluster
Part #: 7E0920960S
Component: KOMBI
Software version: 1104
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 440B010300 (hex)
[No fault codes]
Infotainment system
Part #: 1K8035150L
Component: MU-E-D-ER
Software version: 7085
ASAM/ODX identifier: EV_MUEnt4CGen2LGE
Coding: 065700003C00000041111101008000001F0000C60000010001 (hex)
Fault codes:
00001 Manufacturer-specific code
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907047AK
Component: Climatic-T5
Software version: 0708
ASAM/ODX identifier: EV_ClimaticT5
Coding: 0000000003 (hex)
[No fault codes]
Parking/steering assist
Part #: 7E0919475T
Component: PARKHILFE 4K
Software version: 0212
ASAM/ODX identifier: EV_VW75XParkAssis4K
Coding: 10800A (hex)
[No fault codes]
All-wheel-drive system
Part #: 0AY907554L
Component: Haldex4Motion
Software version: 7620
ASAM/ODX identifier: EV_AllWheelContrHA1VW37X
Coding: 0501 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090B
Component: BCM PQ25 Max4
Coding: E0A4303A0A212031002009747C2B94540F88708F60CE4D60320400220800 (hex)
Fault codes:
01365 Manufacturer-specific code
03442 Manufacturer-specific code
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 030B1A73 (hex)
[No fault codes]
Obtained with Carista 750099 for iOS.
Download app: Carista OBD2
Facebook: Carista
Any solution found for this problem? I am experiencing same symptoms. As it snowed it appeared that the 4wd would not work either. I was wondering if the abs and traction control lights have something to do with it? Also had this sensation of the van braking itself when turning low speed after starting the car.So the plot thickens.... have changed the rear left abs sensor and cleared the faults. The lights are still showing intermittently, sometimes just the abs light, sometimes both abs and traction control. Strangely twice yesterday the van felt like it was braking itself when turning tight left on a campsite.
Running out of ideas myself and need to get it MOT'd next week, so any suggestions gratefully appreciated.
Got my fault codes read and got the following codes:ABS, Traction Control and AWD all rely on measuring the relative speed of each wheel to figure out which one is at a different speed to the others and then take action, so if there is not reliable data they can all be impacted.
Your first step is to get something that can read fault codes, or find a member local who has one, and see what's causing your warning lights.
