204 DSG intermittent momentary power loss
Might be worth data logging the fuel rail pressure to see if the correlates to any drop in power?
Have you got a obd2 dongle?
TORQUE App is very good for live data..
I use the Carista Evo dongle..... Gen 1 dongle works as well.
See here...
Screenshot_20250402_164959_Torque.jpgScreenshot_20250402_164945_Torque.jpgScreenshot_20250402_164903_Torque.jpgScreenshot_20250402_164922_Torque.jpgScreenshot_20250402_164729_Torque.jpg
And @mmi might be able to look at the vcds data when he gets a chance.
I've had a Quick Look at the data from VCDS, it looks like the "Turboc.1 turbin.bypass valve 1 B. 1: pos.feedback - Actual value" drops off from 100% to 5-6% then rapidly builds again rite around when I hit the mark button, both turbo pressures and charge pressure match all the way through the rev range, the fuel pressure is stable, I'm really hoping this is a boost solenoid / valve / actuator issue
So, it looks like I either have a N75 valve failure, or there’s a split / leak somewhere in the valve lines associated with the valve assembly on the underside of the bulkhead.
The three little air filters are as black as the night sky too, so they’ll be replace regardless.
Before I rush off and buy a set of valves and a bucket of vac lines, I’ll wait in the hope that the grandmaster @mmi can interrogate the data properly to backup my thoughts.
Is yours biturbo or single turbo?
There are one or three valves under the bonnet at the top of the engine bay.
edit:
3 on the Bi turbo and 1 on the single.
It’s a 2017 204 DSG twin turbo CXEB engine
I can only see the three valves, where will the other two be hiding?
I think I’ve uploaded the wrong file, bare with, I should be able to get it on my phone to upload
Awesome info, thank you.
I can’t get the log data from my phone, once I’m home I’ll upload it again.
So, which one of the three relates to “Turboc.1 turbin.bypass valve 1 B. 1: pos.feedback - Actual value”?
Do you know of the part numbers for the 3 little air filters? I can’t find them anywhere.
That's all for bi-turbo: 1) turbine vane actuator 2) turbine changeover 3) wastegate actuator
For single turbo there is only one valve - turbine vane actuator.
Sweet, there we go.
Thanks @mmi
That's about turbine changeover valve/actuator.
7H0 129 965
I'd like to see engine blockmap files
1) Ignition ON, engine OFF
2) Engine idling
Also full VCDS Auto-Scan is more than useful.
How-to - create engine blockmap files
VCDS > Applications > Controller Channel Map >
[ Single controller address - 01 ]
[ Login or security access code - Leave empty ]
[ Function - Measuring values ]
[ Output - CSV file ]
Go
The result file blockmap-01-... will be in folder C:\Ross-Tech\VCDS\Logs\....
Note: only VCDS HEX-V2 and VCDS HEX-NET cables have the capability to create blockmap files.
The ECU has a couple of dedicated tests for turbocharger
The most relevant would be these two below (in posts 1 & 6).
First impression:
Any chance the engine has been remapped as seems to generate quite high charge pressure?
The actuators seem to travel their full operating range (just simply finding minimums and maximums).
block map is attached
Thanks. However, the blockmap ignition ON, engine OFF is missing. It's useful as it shows sensors, actuators, etc. in their "rest" positions.
turbo test
turbo output test
It seems that possibly was forgotten to "activate" data LOGging during the tests. Perhaps just "Save" instead of "Log" was clicked as there is only 1 datapoint in the files.
Well, looking into the blockmap data I'd like to see a log file of EGR test - both about cold engine and hot engine (after a minimum of 15 minute drive).
I'd like to verify degree of blockage of the DPF - based on the blockmap data engine idling the pressure loss (differential pressure) across the DPF is fairly high. Also the blockmap engine off would help determine any offset in the reading. The degree of blockage is just a by-product of the EGR-test because the test provides a nice way to control engine air intake.
