just found the video clip from when my CXEB engine first failed to start. . .
id already known it was using a lot of oil, and was planning to get the garrage to look into it at the next service.
totaly normal day. . . went to start the van to head for work,
it cranked, fired, run then shut down.
second try - it failed to start,
this is the third & fourth try to get it on video.
and thats the van shutting of, not me - normaly the van will auto crank untill it fires after seeing the key-crank sinal.
but of this occasion it just cranked and stopped.
fearing the worst - timing belt. . . . . i called the VWCV assist and asked for a Silver van guy.
showed him the vid clip ( and the data about using oil) , . . . he kept cranking it and it finaly coughed into life and ran lumpy as hell.
his opinion was low compression caused by the bore wear and fouled injector/s from the oil contamination, when it fired he said it counded like it was only running on two or three cyclinders. . . . . . for about 2mins of tickover, at which point it started running normaly.
months later - we found out that he was correct.
photos.app.goo.gl
