Or could the nox sensor be faulty as it’s reading high and my not be a true reading .
Well, everything is possible. I'm afraid it's not exactly a cheap part just to try.
However, in your last log, during DPF regeneration the sensor logged average of NOx 380 ppm - which is not far away what I had logged (423 ppm).
Certainly it's a mystery why in post #87 (log 13.7.2023) engine idling the NOx was reading high - in comparison of log 16.7.2023 engine idling after the journey almost 0 ppm (just a flip between 0 and 1 ppm).
Do you know the update code I need so I can try and get it put on but Vw want do it for me I’ll have to try else where
If you mean the code for the ODIS (VW tool), no, I don't have that. Instead the actual file identifiers are the following (3771 the current software, 6168 is the update).
VAG Flashfiles Informations - Version check of VAG ECUs - Update check for Audi, Seat, Skoda and Volkswagen
vag-flashinfo.de
I think the way forward is to
1) update the engine software - to eliminate "false" alarms of P20EE
2) verify the actual amount injected AdBlue using either VW tester or VCDS (never verified myself this works)
3) please can you find any repair history of the van - especially if the DPF has been flushed
why?
a) Because P20EE = SCR NOx Catalyst Bank - Efficiency too Low, The NOx catalyst is part of the DPF - a porous coating in the back part of the DPF. However, with current software the fault might be also be a false one thus masking the real cause.
b) The logged differential pressure across the DPF is possibly "too" good (compared with mine with much less mileage).
I’ve ordered a vcds hex v2 cable
That's excellent - it will be a vast improment in data logging.
