You’ll have a light in the rear step, as only velle’s (and cali’s I think) have them in the front steps. So Pauly makes up a kit that will take the feed from the rear step light. Got them in mine, and they are great.If I don’t have the step lights is this still plug and play?
It’s possible to do it to connect to cab roof light but needs a pillar removed, prob simpler to connect in dash, I can supply kit with a couple posi tap connectors so no wires to cutIf I don’t have the step lights is this still plug and play?
Have lots but only white LED I’m afraidAre these kits still available and are they in red?
Hi mate do you sell just the led bulbs to upgrade the step lights?Yes they are feel free to pm me if you want one
How much are you selling yours for?Have lots but only white LED I’m afraid
Yes mate, standard step lights (rectangle units) are better replaced with dedicated LED units these are £5 each but assuming you have caravelle oval light then you need 4 small led lamps per fitting so 8 for twin slider and they are a few quid a set but need to double check price but you have to split the fitting to install them as they are slightly different shape to normal bulbs (have tried several brands) so don’t go in from the rear as normal lamps do but it’s not too bad just need to remove fitting and use a couple small screwdrivers to pop the tabs apartHi mate do you sell just the led bulbs to upgrade the step lights?
Cheers Pauly but removing pillars and fiddling under the dash is a bit risky for me.It’s possible to do it to connect to cab roof light but needs a pillar removed, prob simpler to connect in dash, I can supply kit with a couple posi tap connectors so no wires to cut
How can I get one of them lol, or who would have one?You can reset with VCDS or Carista app .
