That would be usefulAny word yet on a regen icon?
Whoops. What happens now?Its not a limiter, its a warning "bong" and 100% you deffo have it .
If you're doing it yourself make sure you have access to a genuine VCDS to backup your vans ECU's prior to fitting the dash as it will re-write some items without asking you.
edit- I may have written that without spotting "VCDS User" on your tags
Yes, i had noticed a few versions of the firmware was missing the T6.Whoops. What happens now?
Loving my new 6K redline too.
No van shaped vehicle I can find yet. Need to cut the hole out too.
It’s exactly that - I’ve seen the measurements are litres per minute. Analogous to throttle position, if it wasn’t drive by wire.Has anyone else noticed the 'consumption' gauge is around the wrong way? It should (at least the factory VW) gauge increases with MPG (drive like a vicar it is high, nail it and it is low) however on these clusters it is the other way around and more like a fuel usage gauge (drive like a vicar, low...nail it high).
Yup...here is the comparative guage on my golf with factory digital dash driving in 'Vicar mode'...this is clearly what they were emulating, but I think perhaps missed the correct operationIt’s exactly that - I’ve seen the measurements are litres per minute. Analogous to throttle position, if it wasn’t drive by wire.
I see what you’re saying. VW considered consumption as miles per gallon (higher = better) whilst this considers consumption as milllitres / minute or whatever (lower = better). Both make sense but I guess it’s more useful to have a particular MPG target in mind and aim for that.but I think perhaps missed the correct operation
I find the mpg/range is way out compared with the factory MFD.
I get around 600 miles to a tank but the cluster never suggests much above 360 miles after a refill. It's a bit weird because it's suggests I am getting 50+ mpg.
I'd expect the range to be much higher based on the mpg. I've done about 8k miles since install so it should have learnt long term values by now.
Someone who does 40+k miles a year and wants to get the most from their mileage expenses.Who even looks at the economy of a 2 tonne van with the aerodynamics of a wardrobe
My mate would literally rather have MPG than MPH on the dashWho even looks at the economy of a 2 tonne van with the aerodynamics of a wardrobe
Nerds like me.Who even looks at the economy of a 2 tonne van with the aerodynamics of a wardrobe
Those two things in combination suggest your tank size is wrong. Do you know if you’ve got an 80l tank?I find the mpg/range is way out compared with the factory MFD.
70L tank (usually takes around 63L when low fuel warning comes on). Cluster is set for 70L too.Those two things in combination suggest your tank size is wrong. Do you know if you’ve got an 80l tank?
That is odd. Mine pretty much aligns exactly with the MFD. The only other variable I can think of is speed calibration. Mine’s set so it’s bang on with a GPS speed reading. Hmmm.70L tank (usually takes around 63L when low fuel warning comes on). Cluster is set for 70L too.
