I've got the VGC flush sliding window and has leaked from day one with nowhere for the water to escape apart from the floor.Hi
Not a VGC window. That is the Chinese version that slides rear to front
Not sure about how they operate
Regards
Are you often parked nose-up?I've got the VGC flush sliding window and has leaked from day one with nowhere for the water to escape apart from the floor.
The van is always parked on the drive which is flat, I raised the issue when first fitted them but after initial response got nothing from them, then raised it again with no success. I've cleaned the rubber and applied silicone but not really helped so will give the WD40 a tryAre you often parked nose-up?
Are the window rubbers spotless?
I’ve only ever found water ingress with my VGC Windows when I left the van on wheel ramps overnight and when I jet-washed it whilst the seals had lots of dust in them.
Invoke your warranty rights if you’re still in date.
Otherwise.. Applying WD40 to the seals will swell them, which may help complete the seal.
Who fitted them, out of curiosity?The van is always parked on the drive which is flat, I raised the issue when first fitted them but after initial response got nothing from them, then raised it again with no success. I've cleaned the rubber and applied silicone but not really helped so will give the WD40 a try
I fitted them myselfWho fitted them, out of curiosity?
If WD40 (water dispersant) is applied to EPDM it will swell the rubber but it will also cause it to perish and crack.The van is always parked on the drive which is flat, I raised the issue when first fitted them but after initial response got nothing from them, then raised it again with no success. I've cleaned the rubber and applied silicone but not really helped so will give the WD40 a try
Ah. Did not know that. Cheers @DXXIf WD40 (water dispersant) is applied to EPDM it will swell the rubber but it will also cause it to perish and crack.
The problem with the VGC flush sliding window is they have no drains so water gathers in the channel and overflows at the lowest point.Bought a rear NS slider after about a year in noticed some damp on the C post ( did post in here re this) thought it was the C post somehow
Turned out to be 2 very narrow drain holes on the fixed window part that were blocked dust dirt etc. They drain to the back of the window and down ( bloody rubbish design!)
Didn't have access to compressed air so used some ring main wire to " fiddle" it and cleaned the rubber runner ( I got it mostly out without any hassle) cleaned all used a straw ( needs must lol) to blow the holes thru!
Sorted it! All dry albeit it had ruined the ply panel so had to replace and re carpet.
Been a few months and some serious rain all still nice and dry!
I've twin sliders with different make windows they drain to outside with good long holes to the outside never a problem!
