Yeah the first time I did it last night it didn't work. But the second time it did. So still managed to wake everyone up
I did have some issues initially, but I think it was linked to the rear barn door lock sticking sometimes. The problem went away when the rear lock was cleaned and adjusted under warranty.Yeah the first time I did it last night it didn't work. But the second time it did. So still managed to wake everyone up
Only works with the driver's door openI disabled the internal alarm with the switch on the B-pillar. Now it will not switch back on. Any help appreciated.
I could be wrong but it is also 'one shot' I think - i.e. it only disables the internal movement sensors for the next time the vehicle is locked. You can't use the button to turn it back on. If you want to turn it back on, unlock it then lock it again (without pressing the button). EDIT Can't be bothered to go and get the manual, but on reflection the internal sensors might stay disabled until the next time the ignition is cycled - can't remember which it is.I disabled the internal alarm with the switch on the B-pillar. Now it will not switch back on. Any help appreciated.
No, when it is lit it is telling you that next time the doors are locked the internal movement sensor will be disabled.Tsixty,
Thank you, I'll try it now. I assume that when the switch is lit the internal movement sensors are on?
As Loz suggests, I think it only works if you have the drivers door open when you press it - I think it’s primarily designed for when you want to leave a pet or feral child in the locked car without triggering the motion sensors. You really need to use the switch on door when asleep. That turns off the alarm system and locks the doors without deadlocks so they can be opened easily from the inside.
No, see earlier post.Thanks Ayjay, I'll try it now. The switch is 'lit' now, I asuume this means that the internal sensor alarm is on?
I think it takes several minutes for the internal movement sensors to arm to ensure the air is still and nothing is still flapping around after all of the doors are shut.Ayjay,
I turned the switch off (i.e. it is not lit) and the internal alarm should be on. I even switched on the ignition. My wife, after it was locked, pranced around inside. No sound. Not sure, sounds like a visit to the dealer. Thanks for your help, at lease I can change the switch!
