Audio Upgrade Stage-1 . . . . Blam Relax 200rs Speakers From Skipton.
The tweeter black crossovers have 3x wires.
Odb
-3db
Ground.
So just move the the tweeter plus from 0db to -3db to reduce the sound level.. (they have bullet connectors,)
The crossover is most likely behind the A pillar.
Cheers Dellmassive. That makes sense. Yes I fitted it all myself with the tweeters and crossovers into the A pillars. They're easy enough to get off so I'll remove again and have a look. Do bullet connectors need soldering or do they just unplug? How did you find the tweeters after fitting? The sound improvement overall with the blam 200rs is massive but in my camper the tweeters are just too much and over power the door woofer hence me wanting to adjust....
The bullet conectora just plug/unplug.
Originally I done the same, fitted at 0db, then thought it was to harsh....so moved to -3db...... now months later I've moved them back to 0db.
I think it's due to being used to the OEM speakers sound, then adjusting.... I'm very happy with the blams..... and now back to the stock 0db setting.
Forgive my stupidity here but am I looking in the right place? I've opened up the tweeter crossover box but can only see a soldered circuit board? 20200314_083124.jpg
LOl... No!!!
Unwrap the tesa tape.
The connector are 6inches or so up stream from the box..
Tweeter side of the box has 2wires.
And input side has 3wires...
Unwrap the 3 wire side.
You will find the ov neg and the 2x positive wires, one marked 0db and one -3db.
From memory its,
Black for the neg...
And clear/red trace/black trace for the positive.
I'm confused. Can't see anything labelled 0db and -3db and have a black wire connected to nothing. Can see that the connectors come apart but they're different sizes..... I should maybe not have meddled!!!
the wire diagram is on the cover of the tweeter crossover . . .
heres a pic from my install.. Audio Upgrade Stage-1 . . . . Blam Relax 200rs Speakers From Skipton.
20180802_145632-jpg.26561
so its red tracer and clear for 0db
and
red tracer and black for -3db
Cracked it! I think!? Thanks to your help mate and the pics. Got the other side to do then I'll post back on my thoughts. Massive respect for putting up with my ignorance and lack of basic any sort of common sense! Cheers again.
@Dellmassive Nooby question but the x-over only goes on one side for the tweeters right? Not sure how it works for both tweeters (some serial loop?)
Did you cover your speakers in the door to avoid water? Skipton tell me that their plastic housings dont fit the Blam speakers btw.
Audio upgrade Stage-1 . . . . BLAM Relax 200RS speakers from Skipton.
As the title says, so i thought i would bring you along for the ride . . . . . . . . .
stage 1 was to sound deaden the doors and door cards and fit the new 8" speakers and tweeters.
stage2 will be fitting the amps and sub . . . but for now lets have a look at stage1 . . . . . .
Audio Upgrade Stage-2 - Vibe Micro Amplifier Plug & Play - How I Done It -
Audio Upgrade Stage-3 - Vibe Micro Sub Amp + Jbl Sub - How I Done It -
Audio Upgrade Stage-4 - Kicker 15" Sub + Kenwood Amps - How I Done It -
These are the speaker kit from Skipton Car Audio. (8" 100W woofer plus tweeters and crossover)(plus new mounting rings)(and a set of OEM speaker connectors)
The first this was to remove the door cards and drill out the rivets holding the OEM speaker/pods inplace. A simple enough job providing you had a couple of trim tools and some decent drill bits for the rivets. . . . . plus a few Torx bits for the bolts etc. oh and a spanner for the bottom 90deg twixt fixings.
The rivet mounting holes lined up nicely with the holes in the new collars, but we ended up just fitting new self drilling screws to mount the new speakers and mountings. . . . . you can see the difference in speaker sizes clearly here.
while the old speakers were out we started the sound deadening with, 1x layer of dynamat type mats stuck to the outer skin behind the speaker port and then another layer of dense foam insulation over the top. . . . . . .just had to keep checking that the window mechanism was still free to move. . . . if you wanted to cover the whole outer skin you would need to remove the inner panel, but we wanst that bothered and were happy to just cover as far as we could through the speaker opening.
The next thing was to cover the steel inner door panel with a layer of dynamat sound deadening, i was easy to cut into shape with sharp scissors and stuck on nicely with this hot weather we are having,... . . . .
next was to fit some dense foam to the back of the door card itself . . . . maybe overkill . . . but i was having fun so just kept on sticking . . . .
doors now done it was time to move onto the tweeters in the A-pillar . . .
the OEM tweeters popped out easy enough once the plastic tabs were cut off . . . . but didn't realize that the tweeters had a different connection on them than the woofers, . . . . so ended up cutting off the old tweeter piece of loom and crimped onto the new tweeter x-over . . .
the new tweeters lined up nicely, and with a quick go on the hot-melt glue-gun they were firmly fixed . . .
so put all the panels back together and time for a test.....
The results?
well they sound awesome, even though its still just the head-unit driving them. In stage 2 we have a new 100w amp to run them from. The bass and low-end is massively improved with a nice tight punchy mid-range. The tweeters and top-end clear and precise with great stereo separation.
The sound deadening has made other improvements too, the road noise has been reduced now with a more subtle low-end rumble than before and the door closing sound has nice and reassuring thud when closed compared to the previous tin-can-van type noise. we have a load of sound deadening left over and plan to use it on the roof of the cab the next time the roof trim so down . . . .
Other things to note were that we have a full height bulkhead with no window, this had previously been carpeted on the back side which helped massivley to the road noise preiously . .
Also after we was finished we done a full-van-scan on the Autel Maxisys which showed some error codes logged relating both the woofer speakers being disconnected! obviously set a code when we had the ignition switched on to test the window function wasn't impeaded.... these codes all cleared down with no problem . . . . which was good as the new speakers are rated at 3ohms where as the OEM speakers are the standard 4ohms, so all is withing the range for generating a low resistance fault code. All good.
Total time ? . . . about 3 hours and 6 bud lights =]
stage2 will be soon, using the Skipton audio radio loom so we dont need to cut any factory cables and using a AudioControl LC2i with high level inputs which will also generate a remote Amp switch on feed. Then of course the amps and sub . . . . . but thats for another day.
Hi,
I just received my Blam speakers and tweeters today but the tweeters look different to yours, did you remove the rear backing casing of the tweeter prior to glue fixing?
RT25 tweeters . . . ?
are yours the same? . . . . what BLAMO set did you get?
heres mine below
Hi,
There is a twist off cover that you can remove/replace with other variants (that come in the box). Have you just got a different cover fitted perhaps?
