oooosh another quick delivery =]
I've emailsed ALLPOWERS to ask them about the free extra power supply.
mines charged now . . . . 4hrs via USB-C PD
LOL, welcome to the club =]Hi
Just seen all the product details at the bottom of the advert
Just ordered. Dellmassive I'll have to stop reading your posts first the Noco GB70 now this
Nice panel !!@Dellmassive Just ordered this: Lensun ETFE 100W 12V Foldable Flexible Solar Panel with MC4 Connector, Portable Foldable Ultralight only 3.2kgs/ 7 lbs!!!
Will run a test when I get it and post on here. Just need to find a connecting cable for this to the Allpowers unit and another for the CTEK and I’m away!
I have an electric coolbag that probably draws around 50W (don't know for sure though), which at 12V is then about 4A, is that right? How does the maths work to calculate how long it would last please?
This is all hypothetical in my case
@Dellmassive Thanks! Really appreciate the detail you’ve gone into, you‘ve saved me so much time and removed a lot of the mystery around solar! I’ve ordered the pieces you’ve linked to... looking forward to running the tests when the parts arrive!Nice panel !!
(I've got the 200W version.)
Item Specifications:
Model: LS-100FD-MC4
Rated Power Output: 100W
Optimum Operating Voltage [Vmp]: 18V
Optimum Operating Current [Imp]: 5.56A
Open Circuit Voltage [Voc]: 21.24V
Short Circuit Current [Isc]: 6.11A
Cell Technology: Monocrystalline Solar Cells
Solar Cells Efficiency:21%
Production Tolerance: +3%
Output Type: Solar Cables, Solar Controller
Dimensions(unfolded): 1300 x 570 x 6 mm/51 x 22.5 x 0.24 inch
Dimensions(folded): 580 x 440 x 60 mm/ 22.8 x 17.3 x 2.3 inch
Net. Weight: 3.2 kgs/7 lbs
All Technical data at standard test condition AM=1.5, E=1000W/mm, Tc=25℃
That panel comes with the standard MC4 connectors which is great.
Id recomend getting a MC4-MC4 extension lead (so you can place the panel in the sun, away from the van or ALLPOWERS (like i have)
heres a 15ft example -
MC4 Solar Extension Cable - 15ft 12AWG Pair : Amazon.co.uk: Business, Industry & Science
MC4 Solar Extension Cable - 15ft 12AWG Pair : Amazon.co.uk: Business, Industry & Scienceamzn.to
you will NEED an "MC4 tool" to open the MC4 conectors once they snapped closed.
i ended up just getting a kit which includes the MC4 blue tool, plus a MC4 crimper and some MC4 male/female ends to make up your own cables.
heres and example
BougeRV Solar Crimping Tools for 2.5/4.0/6.0mm² Solar Panel PV Cable + 6pcs Male Female Solar Panel Cable Connector + 1 Pair Solar Connector Assembly Tool Spanner Wrench Tool Kit: Amazon.co.uk: Electronics
BougeRV Solar Crimping Tools for 2.5/4.0/6.0mm² Solar Panel PV Cable + 6pcs Male Female Solar Panel Cable Connector + 1 Pair Solar Connector Assembly Tool Spanner Wrench Tool Kit: Amazon.co.uk: Electronicsamzn.to
i then got either a pre made lead like this:
Torberry Battery Lead Connector with Bare Ends Will Fit Golf Trolley Mobility | eBay
Find many great new & used options and get the best deals for Torberry Battery Lead Connector with Bare Ends Will Fit Golf Trolley Mobility at the best online prices at eBay! Free delivery for many products!rover.ebay.com
or just the ends Anderson PowerPole / Torberry and crimp them on myself.
10 x CONNECTORS WITH RUBBER BOOT COVER POWERPOLE (5 x PAIR) 30AMP 600V | eBay
10XAnderson Power Pole 30AMP Electrical Connector Plugs With Rubber Boot Sleeves. Current : 30Amp. Material: polycarbonate (PC) shell, stainless steel shrapnel, copper, Rubber Boot Sleeves. 5 X Rubber boot covers.rover.ebay.com
Twin cable (Flat 2 Core 3.0mm² 33Amps, 5 Metres) -
https://amzn.to/377qV41
to basically copy the ALLPOWERS lead here:
High Efficiency Anderson to MC4 Solar Charging Cable-Solar Charging Cable-ALLPOWERS
UWBCMS6www.allpowers.net
You could then just make up a short MC4 lead for your CTEK, which would stay connected in the van.
Then when deploying mobile solar, just use the extenision lead above right to the panel.
Solar MC4 connectors are polarity conscious in respect of where the flow of the power is coming from.
So:
Solar panel +ve (power sourse) > MC4 male ----- MPPT/CTEK ---- MC4 female +ve input
Solar panel- ve (power sourse) > MC4 female ----- MPPT/CTEK ---- MC4 male +ve input
so lt goes male to female all the way down to the charge controller.
how to make the ends - MC4 Solar Connectors
see 1.38m here>
Yes, but not 2000W (typo?) (2000W would draw 200A ish) (166A-200A)just i naive thought , could you run another inverter(AC output 2000w) from the 12 volt output just like you would a leisure battery
