thank you
@czmate1999 for bringing this to our attention . .
a bigger version of the 372wh unit . . .
this time 666wh
Great prices on your favourite Gardening brands, and free delivery on eligible orders.
amzn.to
ALLPOWERS Portable Generator 666Wh/185200mAh Power Station Backup Emergency Power Supply Pure Sine wave with DC/AC Inverter,Charged by Solar Panel/Wall Outlet/Car for Camping, Home Use, RV, Outdoor
- ❤Ship from UK local store,generally you will get it in 3-7 days!❤ ▶ 666Wh/185200mAh Huge Capacity: ALLPOWERS portable generator is possibly the smallest and lightest power station on the market. A high-density lithium-ion battery allows for a more compact build than that of lead-acid power packs. Works quietly without raising your voice or feeling disrupted, widely used for indoor or outdoor such as family, office, travel, camping, fishing, hunting, farm or the job sites.
- ▶ 5-in-1 Charging and 3-in-1 Recharging : Off-grid power station for camping or emergency backup, capable of powering lamp, phones, laptop, TV and even mini fridges( Not recommend to CPAP used). ALLPOWERS powerhourse boasts five output modes: a 12V cigarette lighter socket, two 12V/15A DC output, 3 fast-charging USB ports, one Type-C output and two AC sockets. Can be recharged by Solar Panel/ Wall Outlet/Car
- ▶ Bluetooth Connection: Aipower App supports iOS 9.0 or above /Android 4.3 or above. Ultimate wireless stability, with Bluetooth technology that connects your devices in a wink. Start easily and reliably
- ▶ Pure Sine Wave: Operates even the most sensitive electronics, it’s better than modified sine wave, with Intelligent CPU control mode, key switch output, LED display, short circuit and surge protection
- ▶ Safety Graranteed: Battery Management System (BMS) undertakes voltage control, temperature control and more advanced safety operations, ensuring complete protection for you and your devices; and it hazes Zero emissions, therefore does no harm to personal health, nor to the nature
ALLPOWERS High Capacity Generator Meets All your Needs Boasting a remarkable 666 watt-hours of energy, using only premium components and the most advanced power management technology, ALLPOWERS solar generator packs enough power to fully charge your personal electronic devices, household electronics and appliances, jumping start your cars, powering up your tools, and helping you keep lights on for emergency use, charging your laptops, cell phones. It’s great to take in your RV, campsites, fishing, hunting, farm or the job sites. Specification: Battery Capacity: 185000mAh/666Wh Rated Power: 500W Output Waveform: Pure Sine Wave Size/Weight:26.3*14*18cm/10.4*5.5*7inch 5kg/11Ib Protection Circuit: Short circuit, over current, over power, over charge, over-temperature, ect Net Weight: 5kg Input: AC:Voltage100-240V to 20V Current5.0A(at Max.)Please do use the adapter included with the unit,never use an extra or different one. DC:12-30V 10A(max). Output: AC:2*US/JP 110V 500W or EU/UK 220V 500W(surge power 1000W) DC:12V Output:12V5A(5.5*2.5mm)*2 12V Car Port:12-13.6V10A 2*USB:5V3A,9V2A,12V1.5A 1*USB:5V3A 1*USB-C: 5V/3A,9V/3A,12V/3A,15V/3A(PD 2-way,60W/100W Note: When the energy storage is working, the fan will accour a certain sound when it dissipates heat, just like our computer, which is normal Storage and Downtime Maintenance: 1.It is suggested to fully charge it at least once every 90 days for maintaining the best performance, reliability, and longevity. 2.If outputting is done, please remember to turn off the master to save the loss of energy. 3.Due to the chemical characteristics of the battery, the available capacity of the battery may somewhat vary from environment to environment such as cold weather or overheating (you may hear a cooling fan). So please always use it in room temperature (0°C- 40°C)also it is not recommended for outside storage or in damp environments. 4.If you are living off-grid in sub-zero conditions, we recommend you keep your unit in an insulated cooler and connect to a power source(solar panels). The natural heat generated will keep battery capacity at its highest. 5.The battery packs inside are non-removable, nondisassemble, the life-cycle for charge and discharge is over 500 times, but eventually, it will wear out. 6.Continuously discharging the battery to 0% and then storing it with an empty battery may reduce its serviceable life. It is recommended to always leave at least 20% capacity unused. Package 1 Contents: 1x ALLPOWERS portable generator 1x Adapter charger 1x User Manual
- Brand Name: ALLPOWERS
- Battery Type: Lithium Ion Battery
- Features: Support Quick Charging
- Features: with Flashlight
- Features: Built in Cables
- Features: Digital Display
- Features: Charger & Battery in 1
- Features: wireless charging
- Output Interface: Type C
- Output Interface: Triple USB
- Output Interface: DC
- Output Interface: Wireless
- Battery Capacity: Above 100000mAh
- Charging Devices: for Laptop
- Charging Devices: for Tablet
- Charging Devices: for Drones
- Charging Devices: for Camera
- Charging Devices: for Smartphone
- Input Interface: Micro Usb
- Shell Material: Silicon
- Type: Portable Power Bank
- Weight: 5000g
- Size: 26.3*14*18cm
- Support Quick Charge Technology: One-way Quick Charge
- Supports Solar Energy: No
- Quality Certification: ce
- Quality Certification: ROHS
- Quality Certification: PSE
- Quality Certification: FCC
- Is LED Lamp Illumination: Yes
- Colour: Gray match black
- Application: home/outside/camping/traveling
- Model Number: AP-SS-007-BLA
- Controller Type: MPPT
- Load Power: 500W
- Output Frequency: 50Hz/60Hz
- Place of Origin: Guangdong China
- Output Voltage: 110V/220V
- Work Time: 666Wh*0.85/your device power
- Solar Charger Input: 12-30V 10A,150W
