has anybody had the bulb out warning on the dash after this mod from standard lights?
Yep I did... Only because I didn't push the purple lock tab back after fitting the crimps. The tab stopped the connector being pushed fully into the light.
ah ok, will check it outYep I did... Only because I didn't push the purple lock tab back after fitting the crimps. The tab stopped the connector being pushed fully into the light.
How did you get on with the coding?checked all cables, still the same, gonna code later today.
Is this any help ----> Oem T6 Led Rear Lights With Sequential Led Indicator "retrofit"How did you get on with the coding?
fine now its codedHow did you get on with the coding?
What was the coding? I’ve got a bulb error light on my dash, and I’m not sure if it’s the LED tail lamps or the LED numberplate lights.fine now its coded
Bcu Central Electrics Module 09 Byte Screen ShotsWhat was the coding? I’ve got a bulb error light on my dash, and I’m not sure if it’s the LED tail lamps or the LED numberplate lights.
Did you read this?Any ideas anybody?
Did you read this?
T6 LED headlight retrofit?
All parts for my retrofit are now ordered with the exception of the plug and play looms. Other than the looms (to keep the install as simple as possible), I am using all used/second hand parts sourced from eBay to keep costs as low as possible. I won't get the warranty on parts that I would...www.t6forum.com
And this?
‘Light Out’ warning on after tailgate conversion.
I've converted my barn doors to a tailgate with LED lights. But I have a orange warning for bulb out on the instruments. VCDS scan showed no fault codes. If I go into 17-Instruments and go into measured values, what should I be looking for? The only concern I've found is "Status on input...www.t6forum.com
It seems that VW made also some other coding changes related to the LEDs (not seen documented), namely byte 27 bits 2-4 are set to "1" on all van having T6 LEDs also in the rear. In the vans with regular bulbs (barn door) those bits are "0".
Also seems to be byte 18 is "73" with full LEDs (tailgate) and "72" with front LEDs only (barn door).
I'm not sure if the changes are relevant. Anyways, will put out a more refined post later...
Mine worked no bother even with led reverse lights? Is it a coincidence and there's an issue with the headlights?Any ideas anybody?
No I’ve checked every function and all working.Mine worked no bother even with led reverse lights? Is it a coincidence and there's an issue with the headlights?
This code sorted mine out. Whethwr it coded the tailgate LED numberplate lights or the OEM LED tail lamps, I don’t know.No I’ve checked every function and all working.
T6 tailgate tail lamps?Hi all.
I’m changing to OEM LED tail lights. The wiring for the fog/reverse is done but I’d like to use resistors to remove the rapid indicator flash.
Where is the best place to mount the resistors and how?
Thanks in advance for your help.
