Good find. I totally bypassed the CBE stuff and just use the DS300 as a fuse box (for now) and don’t get any flashing lights on the panel. I’ve not even noticed if the EHU light comes on or not. Possibly because I now don’t use EHU with lifepo4 and solar! The battery indicators are useless and (on my poverty 100 panel!) there is nothing else of use other than the basic on/off switches. In the future I will remove it and fit some CBE switches and USB chargers instead. If I want to know what’s going on with the power I use the Victron app. I guess if one has a dual voltage fridge or a better panel it is useful to connect the signal.
This is just it, the information I have, albeit based on reading forums, suggests the trickle charge for the starter only works whilst this hook up symbol is lit.This was what I suggested in my post?
Lithium leisure battery upgrade
Page 8: Instructions My BB1230 is the green stripe model with one lithium setting.... Reading between the lines I can fit the temperature sensor but it would not be adjustable so set at 0c for lithium. The manual you linked suggests a maximum of +2c anyway which isn't really high enough...www.t6forum.com
I highly doubt it's doing anything other than lighting the indicator, I suspect you have separate issues with your starter battery so keep an eye on that.
From my own experience of the battery alert flashing I believe this could be the case.
The solution in post 680998 would have worked but was far more technically involved, soldering a PCB vs connecting a few wires, so wasn't the solution I was after. It also took me a while to get my head around what I was trying to achieve.....
Anyway, happy for now and I will keep an eye on the starter battery. I have now purchased a multi meter, just need to learn how to use it!
