Valdubvee
Cheers Jon really helpful. Im looking at B14's, ARBs and also sticking with Devonports (after much deliberation) so Ill use your settings as the look is very good. However Id need a higher load rating on the roof bars, as I might want to occasionally carry kayaks so might have to go with the VW ones (tho concerned about reports of leaks). Good point re protection tho, I hadnt thought of that! CheersHi thx, in that picture it is 5mm off all the way down on B14's so in theory 65mm however the T32's do sit a bit lower on the front end. The wheels have spacers behind them 25mm front and 35mm rear. The roof rack i think were called 'Sahara' ones they are only light weight with a 25kg limit as we only carry paddle boards occasionally. Never struggled in car parks no problem with 6'6" max headroom. From memory it measures up at 1950mm but its nice to have the bars there if you do get to close to anything![]()
