ABD sell the indicator lamps which they claim are "micro flashing" proof but as the cure is generally added resistance to the lamp to fool the lamp out diagnostic voltage injected there's no point apart from a claimed 1800 lumen lamp output which is actually damned bright though compared to the stock filament lamp... might do that on my H4s as the headlight indicators aren't that bright in daylight
Why are you opposed to LED lamps in the dip reflector as that's the lamp you'll be using 90% of the time unless you drive mostly in rural areas with little oncoming traffic and use main beam... another thought if you code the headlights for both dip and main at once then you'll have orange and white "eyes".
Pretty sure you can't fit an LED projector module in an headlight without separating the shell as the module mounts into the original lamp mounting hole ie. comes backwards through the reflector from the glass side... I could easily be wrong though!
If the H7 headlight takes the same lamp in both reflectors it would be a no brainer to load up one headlight with a pair for an A B comparison, either way I run LED lamps in my H4 headlights and have posted pictures and a Youtube link on other threads on here
to give an idea of a relatively cheap and cheerful improvement in light output.
