i dont have one of these bike racks but if their easy to remove/steal take it off and put it in your van
Yeah definitely agree with that point, so may as well stick with the stock anti tamper torx onesto be honest all the anti tamper bolts screws sockets the bits for undoing them are readily available some of the fencing we install has anti tamper fixings but we can get all the bits on the internet so any would be thief is going to come equipped and it would be no harder to remove anti tamper than standard fixing
Already do that when the bikes are on & popping in somewhere, got plenty of Kryptonite D locks & flex cables, & Oxford Monster chains & locks, was more concerned about the rack itself when I'm off riding for hours & van parked up, but think I'm probably just overthinking it!True, but space constraints are often an issue...
Or if you're really worried, put an a Almax 19mm chain and squire lock around the bikes. Cant see then bothering to go to the trouble of taking the bikes subject to one of those
Now that makes a lot of sense, so I am probably just over thinking it then, cheers for the inputI think standard towbar racks get nicked at trail centres a lot which is why I always took mine off and put it in the car until I got a T6. With the towbar racks they will fit any car and are therefore highly nickable.
With the T6 tailgate rack it is much more niche, as they only fit a T6 so it’s not the sort of thing that will be nicked opportunistically. The resale market is absolutely tiny compared to towbar racks.
I’ve got the tailgate rack myself and when I park up at trail centres or anywhere else for that matter I don’t give it a second thought. I would echo others and say don’t worry about it. The chance of it getting stolen is very small.
Recently bought a Thule Wanderway tailgate rack (which is fab!), but like other similar racks is only secured by 2 security torx screws, and I now realise that you can remove the rack without opening the tailgate if you're prepared to lose the two lower clamps, which I imagine are easily obtainable & cheap spare parts. So a little paranoid about having it nicked while I'm out biking & parked up at local woods or trail centres. I'm sure I've read about people having them nicked.
Has anyone replaced the torx bolts with anti-theft bolts or have any to recommend?
I had seen some anti-theft bolts online and thought I'd sussed it, but having now had quotes, they are mostly min order of 10 & up to around £140 for 10 & the bolt head socket, which is a bit steeper than I was expecting and think there must be another solution. Are 2 hole pan head bolts any more secure than the hollow torx bolts?
Anyone tried anything or do people just make do? May be overthinking it, but having had things stolen before, I'm probably a little more security conscious than most and curious what others do?
Thanks everyone
You’re right, the VW carrier arms are universal and compatible with other Thule carriers, they can just be clipped off. You can screw the frame clamp tight and then lock each arm using the key but I never bother.Did you go any further down this road, Nick?
I've just fitted mine today, and as long as someone has the torx tool, I reckon they could get the whole thing off without opening the tailgate ♂ Also, (haven't put my bike on it yet) am I right in thinking the attachment arms aren't to be left on the rack when the bikes aren't on...? Cause they can just be unclipped right? They're not locked on either?
Cheers.
@rolling_stone generally just leave it as it is on a day to day basis, unless leaving the van somewhere a little isolated when off biking, then I put a Kryptonite D-lock around the lower arm & use a Kryptonite flex cable & run it behind the sparesafe lock on the spare wheel carrier as a deterrent. Still in 2 minds whether this just draws more attention to it or not ¯\_(ツ)_/¯Did you go any further down this road, Nick?
Cheers.
Code: | Product: | Quantity: | Price: | Total: |
A2MSTHP06060 | M6x60mm TH8 2-Hole A2 Pan Head Security Screw | 1 | £ 1.03 | £ 1.03 |
SECTHDR8 | TH8 (#14) 2-Hole Security Driver Bits | 1 | £ 3.50 | £ 3.50 |
A2MSPTB06060 | M6x60mm T30 6-Lobe Pin A2 Button Head Screw | 2 | £ 0.48 | £ 0.96 |
WIBTP30X25 | Wiha Standard Bit Pin Torx TX30 x 25mm 01732 | 1 | £ 2.88 | £ 2.88 |
WNL6 | M6 Nord Lock Wedge Locking Washer NL6 | 2 | £ 0.38 | £ 0.76 |
CARRM48P | Royal Mail Standard Tracked (3-5 Days) | 1 | £ 3.54 | £ 3.54 |
Net Total: | £ 12.68 | |||
VAT: | £ 2.53 | |||
TOTAL: | £ 15.21 | |||
Thanks for saving me the trouble. I understand someone will take if they want it enough, but im all for making it a bit harder.A lot on this .... I have done the following to my VW rack . The whole kit for under £16.00 from TC Fixings.
Two different secuity heads needing two different driver bits
Code: Product:Quantity: Price: Total: A2MSTHP06060 M6x60mm TH8 2-Hole A2 Pan Head Security Screw 1 £ 1.03 £ 1.03SECTHDR8 TH8 (#14) 2-Hole Security Driver Bits 1 £ 3.50 £ 3.50A2MSPTB06060 M6x60mm T30 6-Lobe Pin A2 Button Head Screw 2 £ 0.48 £ 0.96WIBTP30X25 Wiha Standard Bit Pin Torx TX30 x 25mm 01732 1 £ 2.88 £ 2.88WNL6 M6 Nord Lock Wedge Locking Washer NL6 2 £ 0.38 £ 0.76CARRM48P Royal Mail Standard Tracked (3-5 Days) 1 £ 3.54 £ 3.54
Net Total: £ 12.68VAT: £ 2.53TOTAL: £ 15.21
