Rears are all same size.With the vans that have big brakes; are the rears bigger too, or the same as the rears on other vans?
Just had mine in for a service. Advised to change both discs and pads all around. Need to find a good local independent I'm sure that the price will be better. 30500 miles covered from new. Not that impressed they don't seem to have lasted long . California 4x4 204 and auto.
I had to change my rear disk and pads at 16k! Badly rusted disks and they ground the pads down on the inside to nothing.Just had mine in for a service. Advised to change both discs and pads all around. Need to find a good local independent I'm sure that the price will be better. 30500 miles covered from new. Not that impressed they don't seem to have lasted long . California 4x4 204 and auto.
Half the price I paid, are they easy to do? Might have to invest in some proper gear.I had to change my rear disk and pads at 16k! Badly rusted disks and they ground the pads down on the inside to nothing.
I posted a how to for the rears, got Brembo from ECP
I've just been charged £750 to replace all.
Back in the days of the T3, brake pads probably still contained asbestos and disks were solid chunks of iron that never wore out. Nowadays, disks are made of material to compliment (give best retardation) the healthier stuff that the pads are made from and as a result are almost as sacrificial as the pads. The also rust a lot more.Am I reading this correctly - you need new discs on a sub-3 year old vehicle? My T3 had new discs after 25 years but they were not worn out - still well within specs. Has longevity declined that much on VW parts? Pads are a general service item but discs?
Loz, I guess its difficult to access, but would you think these pads/discs are at least as good as VW-OEM?I had to change my rear disk and pads at 16k! Badly rusted disks and they ground the pads down on the inside to nothing.
Better, purely because of the disks are painted and UV coated.Loz, I guess its difficult to access, but would you think these pads/discs are at least as good as VW-OEM?
Does anyone know what's involved with converting to the bigger front discs? Are the calipers the same and just a different mount and disc?
The calipers are two pot large type with a larger disc as the smaller set up are single pot calipers with smaller disc ! I have looked at changing my small brakes but just buying the calipers alone will fetch you back around £600 second hand then you need the discs and pads , the only other way is to go is aftermarket aluminium 4 pot calipers and discs which will set you back in excess of £1600 depending on the brandI was wondering this today too, when I noticed ECP sell calipers also. When it comes time to change the front discs and pads, would sourcing the larger calipers and caliper carriers be all that's needed. Good time to change the brake fluid if the calipers are getting changed. However, would it be a mod that can only be done on the T32 hub and strut assembly, or could it be done across the board.
