Brake disc replacement Scottish Borders
Barley53
Hi all, looking for recommendations for supply and fit of all four brake discs on a 2019 t6, ideally near the Scottish Borders.
I'm not adverse to travelling anywhere in the UK if it's the considered opinion of you all that its worth it, I've had a good few upgrades to the van all based on forum advice and never regretted any of the work done, but my spare time is a bit shorter these days so anywhere nearer home would definitely be preferred.
For info, VW advised that discs are wearing out (I've no reason to doubt them, they are the original discs), they've quoted over a grand to supply and fit.
thanks in advance.
If you have a trusted local garage that is happy to fit your supplied parts then I'd get a set of the Nutexa posted up and have someone fit them.
I've got them on the rear and they are fine. I have uprated fronts but did them before I'd heard of Nutexa.
I changed from oem brakes for the same reason as you - a ridiculous quote from VW for the fronts.
I bought the uprated discs and pads, axle stands, jack, torque wrench, special splined socket, breaker bar and it still came in cheaper than the VW quote, but that was obviously doing it myself.
Find a garage that works to proper torque settings and does things properly though. I'm always paranoid that they'll just tighten things up 'tight', which isn't why there are published torque settings for things.
Or faillng that get Dav-Tec to do them and incorporate it into a few days away in the Peak District.
