Jodieboulton1987
214,000 miles
Hey all , I’ve just replaced all my discs as my MOT is coming up & I had an advisory last year that ‘Brake disc worn, pitted or scored, but not seriously weakened’ so even though I’ve only done 3k since last year I thought I best change them as it would like be a fail not an advisory this time . I did the pads last year for the MOT so they still have plenty of thickness left on them given that It hasn’t done much mileage.
So basically after fitting all the discs I took it around the block to test out the brakes. It was running fine, then when I braked at the roundabout I noticed I could hear slight grabbing. I drove about 30 seconds back home & there were wear rings on all the discs & they were warm considering I only broke once for the roundabout. It’s as if when when I depressed the brake the piston hasn’t retracted properly.
So jacked the one back wheel up, spun the wheel and was resistance. So took the wheel back off, removed the calliper to check the pads were located correctly and free of any debris that would cause the discs to mark. They were fine, took lid of brake fluid reservoir, wound the piston back In and re assembled. Spun the wheel , all good, lifted handbrake , whee didn’t turn , fine, released handbrake, spun the wheel all fine no resistance, pressed the brake pedal then tried to spin the wheel and it went about 2 spins and could hear it grabbing.
Does anyone know what could be causing this, there are wear rings on all the discs, which would be coincidental that all the pistons are playing up, when they were done before. Any help would be appreciated.I’ve uploaded some pics of the wear rings being caused on the discs& a few ‘during’ pics to see if anyone can see anything obvious that could be causing it. Also apologies if this has been discussed before. I did have a quick look but couldn’t find something the same.Thanks guys.
