Hi DXX thanks for reply, mine doesn’t look like that and not as accessible, the problem is higher up behind dash.@Tony P
If it’s not a warranty job and you are feeling practical how about repairing the arm rather than replacing whole components? Possible a case of freeing up sticky / seized flaps and refitting or repairing the arm.
Not sure if this video and forum link are relevant.
Shuttle HVAC Unit
Is there any service info available regarding the rear HVAC Unit fitted to the T5 Shuttle? I took the rear access panel off in readiness to remove the whole side panel and noticed that the lower white plastic rod was broken on one end. When looking at the two fitting points, it is clear that...www.vwt4forum.co.uk
Hi tony...just out of interest how did you get on with the second opinion?Hi Forrest thanks for your reply looks like I have the same diagnosis
Getting a second opinion tomorrow.
Thanks again.
Hi Forrest, Niknak from the forum came around and narrowed it down to to a broken plastic arm on the unit that opens the flap for the hot air.
Have moved it to hot position manually.
He’s a top bloke and very helpful
Still have to get broken part out and replaced for a permanent fix.Great hopefully sorted then.
take the black panel out under dash in drivers side, it’s on the left hand side as you look up.mines same how did you get to the arm
cheers matetake the black panel out under dash in drivers side, it’s on the left hand side as you look up.
No worries, good luck getting it sorted.cheers mate
