I haven't used a multiflex. I've modified the Cali T6 solution. The T6 frame has been turned upside down for starters. I now get all the advantage / flexibility the Cali system offers.
Other mods required:
The frame rear locking bolts were obviously repositioned on the down side but also inboard by approx. 15mm to enable them to sit on the rear bracket cups. I made up steel plates for the bolts and secured with rivnuts / m5 capheads. The offside bolt was also moved further forward to accommodate the furniture bracket position.
The rear brackets are both original offside bracket I cut down to suit. 1 cup was reposition to suit.
The front brackets:
The offside is an original Cali bracket relieved of its arch mounting bracket. Tidied up and mounted on the furniture.
The nearside front is a 10mm block of ali that I machined into the mirror of the offside profile and mounted on the arch bracket saved from the Cali.
I just need to tidy up the finish to complete the install..
Pics to explain..
