Good spot - I saw that post and looked at the bed (as I have one too and hate the lack of side plastics for us RHD users) but didn’t notice the cooker.@j4ckal I'm confused cos I've just seen your post about new seat covers and it looks like you have California cupboards and bed. Can you buy them to fit yourself?
In reference for future converters. The Cali bed and Evo 7.4 furniture are a perfect fit together. It was a tense moment fitting the bed in the rails but perfect.
I've had a new RHD mattress made up and now have a working bed and furniture
Would it help you if I gave you some measurements from our cali units?
Great job Wills!
Would you say the depth of your Evo 7.4 (34cm I believe) is the maximum amount possible to fit with a Cali bed?
It certainly looks like it from your pics.
I'm also looking to do the same as you but would like a standard fridge rather than a top loader. Knowing the max furniture depth would really help with planning.
Cheers!
The depth of the unit where the fridge is housed is 420mm. Fitting the fridge there utilises what would otherwise be a wasted void area. You lose storage area when fitting a standard front opening fridge IMHO.
The most useful measurement is the gap / distance between the front of the units and the C pillar, which is where the seat / bed will reside. That measures 1180mm.
I just removed the drawer to make the seat lighter to move.To anyone with the 2 seater Cali bed - do you ever remove the main underbed drawer? If so how easy is it to do that, and what kind of space does that void leave you with? dimensions?
For sliding in long things like pipe work, wood, skis etc.
Can’t seem to find much info on this. Thanks!
So the restrictions are at the rear of the seat; two steel down pointing brackets (probably seat belt mounts but can’t see at the moment). These two brackets limit the height to 13cm with a full width of 68.5cm.Great stuff @DXX. And once the drawer has been removed, roughly what size aperture does that leave you with, height and width?
The good thing about the Cali’ bed when compared to others is the seat is the correct height so your feet are not off the floor and as a result when in bed mode there is plenty of headroom. Some other bed systems seem to biased towards under seat storage instead of human comfort.Thanks @DXX really helpful! I’m definitely going to get the Cali sliding bed I think. Any limitation under the bed is far outweighed by the ability to shift everything forward on rails. A sketch would be amazing if you had time![]()
