Confuse the situation more how about the rover 200 diesel with three glow plugs on a four cylinder? Or perhaps that forth cylinder was for showAnd in a Transit engine?
Don't try to teach grandmother to suck eggs!
2x V16 British Polar generator sets on Oberon class Diesel electric sub’. Betty Swollocks every day.Looks a little like our back up generators for our site
In-cylinder glow plugs are only heated electrically for cold starting. During at temperature running they serve a secondary function of emitting residual heat from the previous combustion to aid in efficient combustion of the compressed fuel/air mixture when the fuel is injected. A glow plug has to be heated to glowing to start a cold engine. Does anyone think it then cools off once the electrical current is turned off?
Sorry, I thought we were on the T6 forum talking about VW diesels, which use secondary residual heat from the in-cylinder glow plugs as part of the integral design of the combustion chamber.And in a Transit engine?
LolSorry, I thought we were on the T6 forum talking about VW diesels, which use secondary residual heat from the in-cylinder glow plugs as part of the integral design of the combustion chamber.
They come with the cambelt kit anywayMeanwhile, back to cambelt service...
when I get mine done, I am also going to replace the other little rollers and tensioner as the bearings can get a little noisy over time.
I think there may be a basic misunderstanding about ignition timing, which on diesel motors is controlled by the compression cycle and glow plugs and is not adjustable as there are no spark plugs, injection timing of the fuel, which is electronically controlled, and cam belt timing, which controls the physical relationship between the movement of the valve train and the pistons. If that is not correct there could be catastrophic damage to the engine, even if the belt itself is in perfect condition. Sounds like there was something else going on. If I were told by a mechanic that stalling on a roundabout could be remedied by changing the cam belt, I would find a different mechanic.
The price is approx what I paid (including vat)with breeze vw dealer here in Southampton . YesHi all, have been reading this thread (all of it!) with interest.
My van is a 66 plate 102ps and has done 50,000 miles, bought second hand last summer.
It’s now due an annual service, so I think I’m going to get the water pump/cam belt done at the same time.
I understand that there was a cambelt recall, which kind of makes me think that going to a dealer is the way to go, to see if it’s affected by this or anything else as I’m not sure of the service history.
Was originally thinking of going to a local independent, but they won’t know this presumably?
I’m near Hampton Court in SW London, so Lookers in Hersham is the nearest I believe, anyone used them?
They are quoting £179 for an annual service and £549 for the cambelt and pump, is this reasonable?
Any advice or feedback welcomed! Thanks.
Thanks for the quick reply!That's an ok price.
I’ll see if the van is affected by the recall, and if so I’ll be expecting a discount on the £549 price!
Will report back.
I’m also going to ask them to look at an intermittent fault with my passenger side fog light which intermittently goes on or off. Any advice on any DIY troubleshooting before I take it in?
