The workshop procedure starts with draining the coolant.Does anyone know if it gets a full refill of fresh coolant if the pump done at the same time?
Should do.Does anyone know if it gets a full refill of fresh coolant if the pump done at the same time?
Different in mainland Europe to us as well...and that was when we were still in the EU.Told 7 years or 105,000km by vw in Australia.
Doesn't make sense that its different in different countries.
Same belts, same engines by vw Germany.
Like I said in earlier post had water pump failure on an Astra van about 15 years ago! No warning signs what so everWould there be any giveaway signs of this progress of failure before the belt succumbed? Really need to hear from someone whose belt has failed, prematurely or otherwise.
I think I read it on here somewhere, but anyway it's why I did mine at 5 years even though it only had 42K miles on it. I was more worried about the water pump failing and the consequences than the cambelt.so sticking my head out here . . . .
i was under the assumption that the reason was . . . . . .
that the water pump on these engines were prone to leaking via its bearing. . .
which would cause the bearing to fail. . .
which would put strain on the rubber timing belt,
and eventually loose a few teeth. . . and cause the belt to fail . . . causing engine damage.
so . . .
i thought that the short interval was to get the belt & water pump replaced before it had a chance to start leaking and break the belt.?
More preventative maintenance. . .
I cant remember where i heard this from?
and more than happy to be told otherwise . .
The water pump, pulleys and tensioner that came off looked in good nick as well, all bearings smooth and quiet etc. I was in two minds about it as the belt looked good through the inspection cover and the tension gauge was fine. £429 all in at the local VW specialist.@NeonCycle that looks mint. How much do you want for it?
nice one @Noddy996 but Do hope your not having troubles with your Van .... its all about peace of mind people touching our kitMine’s there as we speak @Mud Digger - totally agree with the recommendation, Steve really knows his stuff!
