Hi, they don’t seem to advertise and they don’t have a website.Nigel, I think you've named that garage before on here but refresh my memory please.
Drive past the garden centre and its in a large industrial estate on the left before you reach the Weighbridge Pub (worth a visit for their famous 2in1 pies).Next to the garden centre?
They have some great stuff, even stuff you want but don’t need!Oh chandlery, that’s even better than stationary![]()
Seems madness (and unacceptable) that the Cambelt needs changing after 4 years when my T6 has only done 31k campervan miles. Price quoted by VW dealership is a whopping £800 (way too expensive)!Just for peace of mind I had my cam belt, auxiliary belt, water pump and pulleys changed on Wednesday this week.
I have a 2016 (Euro 5) 140 LWB Kombi and with 100622 miles it was certainly within the window of pessimism.
Both belts and all pulleys in excellent condition with the only sign of age or wear being slight noise when spinning the two smallest diameter idler pulleys.
Have you read this whole thread?so how come VWT6 cambelts don't last a simular time/milage?
Not as yet, will do when I have time (lots to read|)Have you read this whole thread?![]()
Thanks for following up on this. A member of the VW California Club also tried to persue this with VWCV UK, and when he asked why the difference from Germany, was told it was based on information “not available to share.” Really.I've actually been in correspondence with VW Customer Support about this as well. I told them that my understanding was that VW Germany only required a belt change 210,000 Km with no time limit as long as inspections were carried out as part off a service whereas I had been advised by my dealer that VWUK policy was 120,000 miles or 4 years. After a couple more exchanges, the VW response was the requirement for my van (2018 150PS SWB Highli) was actually 133000 or 4 years. I asked why the difference and they said it was because road conditions and weather were different in Germany. When I pointed out that I had lived and worked in Germany for a long time and that in my experience, road conditions were generally better than the UK and the climate was harsher in a lot of Germany, they came back and said that there technical people couldn't comment on Germany but that's the way it was in the UK (ie. suck it up!). They didn't mention dusty conditions at all. I therefore asked for the name of the UK CEO which they refused but did give me the name of their 'Director Volkswagen Commercial Vehicles' - Cian O'Brien if I wanted to take it up at a more senior level. I really do believe the this is profiteering on the part of VW UK but can't decide whether I want to push it any further as I think I'll just be peeing in the wind. That said, it really does irritate me as I doubt I'll have done much more than 12000 miles by the time 4 years is up and the belt has to be changed.
Assuming it was an older MX5 then it's a clearance engine so no worries when it snaps other than needing a tow home!Seems madness (and unacceptable) that the Cambelt needs changing after 4 years when my T6 has only done 31k campervan miles. Price quoted by VW dealership is a whopping £800 (way too expensive)!
My MX5 did 80k with original cambelt without issue so how come VWT6 cambelts don't last a simular time/milage?
I've never grasped how a high CR (diesel) engine would increase cambelt load when you consider that the crankshaft drives the camshafts. Surely as the compression load is within the cylinder it would only act upon the rods and crank. I appreciate that the poppet valves may need slightly higher force to open but I cannot see this being significantly more, especially when the cam lobes are typically lower.Belts on diesel engines tend to be wider and hopefully stronger than those on a petrol engine, the higher CR of a diesel does put more strain on the belt...
The point about "clearance" is a good one.... I've seen many petrol engines have a belt strip but not touch a valve, I've never seen a diesel engine that did it's belt "get away with it" Bent valves, snapped camshafts, cracked cam bearings, heads destroyed, cracked valve guides........the list goes on...
