Ditto the auxiliary belt which has to come off for access. Much cheaper to just change it while you're in there.
Just had mine all done and they showed me the water pump. This isn’t any ordinary pump like the old days! I will try to explain........as well as the vanes which are permanently driven by the cambelt there is a circular steel shroud which goes around the vanes which is electric powered and controlled by the computer. When cold this shroud goes around the spinning vanes and prevents water being moved (so engine heats up quickly). As engine warms this shroud is retracted which allows water to circulate. So the water pump as well as being driven by the cambelt also has electric connections, some moving parts, a connection to the brain and more to go wrong.The water pump is purely a “whilst your there” service item based on the total labour over the cost of a water pump.
when I get mine done it will also be all rollers and tensioner etc.
Hopefully it’s designed for default full flow if the control system fails.Just had mine all done and they showed me the water pump. This isn’t any ordinary pump like the old days! I will try to explain........as well as the vanes which are permanently driven by the cambelt there is a circular steel shroud which goes around the vanes which is electric powered and controlled by the computer. When cold this shroud goes around the spinning vanes and prevents water being moved (so engine heats up quickly). As engine warms this shroud is retracted which allows water to circulate. So the water pump as well as being driven by the cambelt also has electric connections, some moving parts, a connection to the brain and more to go wrong.
mechanic said that in his opinion it Is vital to change the pump as well as the cambelt.
hope you follow a layman’s description and happy to be corrected.
Mine is 4 years old this week, my pump had a big electrical cable on the back - can’t see one on yours?Which year van do you have? This is (was) my pump, admittedly as a Euro 5 it's not strictly a T6 lump...
I’m a numpty with engines but the mechanic did say there are 3 more water pumps but this is the only one driven by the cam belt.Do you have an auxiliary pump on yours?...
As you can see from posts above I was in the same situation but decided to go to a local independent using genuine VW partsI was just quoted £630 plus VAT from my local VW.![]()
i think this is the one, you can see the retractable shroud. (And it’s about £150.00!)
Well it would appear my indie knew what he was talking about - he said that the waterpump was a bigger risk than the cambelt. Unfortunately as I have the extended warranty we had to use VW parts but next time we will look at the pump in the video as it appears to have the electric connections but not the shroud.Looks like this type of pump has reliability issues. If my MY16 Euro 5, 180ps has one fitted I’ll be looking to replace it with a non shrouded pump when it’s time.
I also found this regarding VW pump failures in the USA and lack of water pump maintenance schedule in VW documentation / manuals.
Hi, yes it was. Spoke to another VW in Devon as I work that way and they quoted £540.Was that SMG Tonbridge @Rg_?
The whole concept of the 210,000km max without time limit depends on the belt getting inspected at every service.Very interesting and an eye-opener. It certainly seems we as UK VW owners are just cash cows and of course the garage industry won't object, neither would I if it was bread and butter. I have had Kias for the last 11 years and I have my daughters Picanto which had its 7-year service in Feb, all done by authorized Kia garage, and not one word has been said about a cambelt change. If it is good enough for the European market, VW, at 210,000Km then it's good enough for me.
The problem is, we do succumb to, It could snap or the water pump may fail. Well, that could happen at any time if you have a faulty belt or pump. I wonder how many T5 or T6 are running around France, Germany that has had the pump and timing belt changed at 4 years? Some may say, I'm not taking any chances but if it hadn't been drummed into the UK market, 4 years, would you be saying that or running the course and perhaps getting it changed at say 10 years if the said mileage hasn't been achieved? Food for thought.
