Clearing the Air bag warning light
When my leisure is low, my CTEK jumps to around 14.7v initially. It’s set to AGM which is correct for mine.
I did the same, but just waited a couple of months until the service was due. It's only a small light, you stop noticing it.
In my eagerness to install my new shiny glove box lid I inadvertently ended up damaging the passenger airbag switch when pulling it out causing an error light to flash up on the dash on turning ignition on.
I have installed a new one from VW this morning but the airbag error light is still showing.
Carista shows the following (attached) if I were to purchase the 1 month would this reset my issue or do I need to book it into VW for a reset ?
I think you can get a one month free trial, which enable it to be reset. Just remember to cancel it or it’ll take about £48 off you.
I disconnected the wires from my seats to get them re upholstered and when they were disconnected I forgot and turned the ignition on. Now that the are all plugged in again I get the Air bag warning light on my dash. Would it just need clearing with the dealers computer .
I just dont want to wast there time and mine .
If the seat is back in the code will reset.
Either from dealer or get your own tool.
Or try a battery reset to clear the code....
Hi,
After watching some YouTube and as well reading some posts here, I'm getting a bit confused. I have got Android on my phone, also the issue of subscription upon download the apps to support these gadgets.
So, question... what will be the best advice to buy, to clear the Airbag warning light on my T6 KOMBI 2019?
CARISTA OR OBDeleven?
Thanks a lot guys,
J.D
Carista is the easiest/cheapest device for resetting faults
Reactions: J D
